Twin Fans
Jun 23, 2009 | 03:33 PM
Twin Fans
Im running twin fans on my front mount and they keep popping the fuse!
its a 30 fuse. would it be ok to use a larger fuse?
Jun 23, 2009 | 03:36 PM
ya would be better off making a new circuit for it with a relay, it it dont pop the fuse, it would probably melt the fuse ,box and loom!
Jun 23, 2009 | 03:38 PM
yeah might be a good idea.!! dont wanna be melting my loom!
Jun 23, 2009 | 03:48 PM
nope, coz it would probably melt the car to lol
Jun 23, 2009 | 04:09 PM
*** Sierra RS Custard ***
I would personally sooner relay them seperately and use 2 single 30a circuits than run any more current than that for 1 wire.
Jun 23, 2009 | 05:12 PM
You'll probably find it's popping the fuse for a reason! Could have a short in there somwhere. New circuit relay'd off is the answer!
Lee
Jun 23, 2009 | 07:08 PM
Can i rewire a relay between the fans and the fan sender? Or should i Just put a switch in?
Jun 23, 2009 | 07:18 PM
Yes you can put a relay on the fan sender, if you do then you can also put a switch into that as well, so that you can manually override it if you wish.
Jun 23, 2009 | 07:20 PM
It just I want the fans to kick as they would normally, but then have the option of switching em on if i get stuck in traffic etc..
Im just struggling to get my head round how to wire it!
does anyone know how this could be done? diagrams would be sweet
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
