cosworth parts,poly bushes,clips,arb bushes odds and ends
Old Jun 21, 2009 | 03:03 PM
155lee's Avatar
155lee
Default cosworth parts,poly bushes,clips,arb bushes odds and ends
having a clear out of some bits i wont ever need again,heres a list of what i know about,ill add in tomorrow the things i cant remember today.
rear trailing arm poly bushes,1000 miles use,inner and outer bushes,these were the expensive 1s,not the cheap crap,with inserts,£20
front tca inner poly bushes,in purple,1000 miles use,same again,expensive type,like new with inserts,£10
2 rear sapphire trailing arms,in need of a repaint,no bushes.£10 each
front tcas in good condition,4 of £7 each
front tca outer bushes,genuine ford,new and unused,£15 for all 4
various standard boost hose,£5 each
i have 2 recaro seat frames which have knackered foams,the frames are good so if anybody needs any parts from these please ask.
bumper insert mouldings,used so will need new adhesive tape,£5 each
front grille insert with ford badge,£5
sapphire cosworth front anti roll bar,£10
cosworth 4x4 rear driveshafts,£10 each
4x4 cosworth rear hubs,£10 each
cosworth 4x4 rear driveshaft outher splined cvs,£10 each
cosworth 4x4 underbonnet sound deadening clips,new in bag,£7
cosworth 4x4 underbonnet sound deadening,pretty used but still presentable,£10
sapphire rear outer window rubber,mint condition with no bubbling,cant remember which side,£20
sapphire cosworth black carpet,cant remember how good it is but it needs a clean,£15 if its good
cosworth bailey dump valve tee in chrome,i bought it new and had it fitted for about 6 months so is still m int,c/w piece of small i.d tee to d/v silicone hose,£10
ill add any other bits i find tomorrow when i get home,cheers,lee
Old Jun 21, 2009 | 03:53 PM
fezzajsy's Avatar
fezzajsy
got any rear arb bushes for a 4x4 sapph mate?
Old Jun 21, 2009 | 05:39 PM
155lee's Avatar
155lee
No sorry,i bought a full car set but when i did my underside rest i used a rose jointed rear beam and adjustable tcas,i am using the poly bushes where i dont have rose joints.
Old Jun 21, 2009 | 05:40 PM
andy130's Avatar
andy130
silicone hose is that the piping for dump valve ect?if what colour
Old Jun 21, 2009 | 06:03 PM
155lee's Avatar
155lee
yes,the short piece from the top of the tee to the dump valve,it is blue in colour,the tee is chrome.
RB26DETT
17
May 27, 2016 11:26 AM
Wilsfoci
15
Mar 30, 2016 10:26 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
