Cosworth parts + TT38
Im having a clear out and here are a few bit i have up for grabs .
If you need pics for some parts ive listed just ask .
TT38 turbo , 1200 miles use , i was going to use it but changed my spec to standard power due to my insurance being too god damn high . No play on the shaft , looks new but i havnt tried it on the car its just been stored for a year in my loft .
£650
Grey injectors with fitting kit ,New , fitted but never used due to spec change .
£150
3 Dr cosworth rear roll bar , freshly painted looks like new £40
4x4 cosworth fuel rail and nearly new regulator (reg done 200 miles) SOLD
2wd koni suspension struts rear and front ,need painting, no springs as they where rusty and paint flaking off . £70
Black diamond 4x4 front discs Grooved and drilled done 200 miles surface rust only thin , no wear or lips . £50
4x4 calipers and red stuff pads , pads done 200 miles easy driving . £80
3DR cosworth heat shield , has small hole and one mounting bracket missing . £20
2wd cosworth brand new lock set , 2 door locks , boot , ignition and petrol cap . £80
Fuse box lids , black . £10 each
Clock . £10
Alloy header tank 2wd . £80 .
4x4 vibra technics engine mounts , done 200 miles £100.
4x4 sump needs sump plug retapping £30
4x4 cosworth lower steering rack joint . £20
Sapphire slam panel , new not genuine .£10
Parts can be delivered if needed .
£650
£150
Clock . £10
3dr cossie
11
Dec 21, 2015 03:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
