torque and bhp dont cross at 5252 rpm ?
Old Jun 18, 2009 | 08:47 PM
scoooby slayer's Avatar
scoooby slayer
Default torque and bhp dont cross at 5252 rpm ?
if the bhp and torque dont pass at 5252 rpm is the dyno printout inaccurate ?
Old Jun 18, 2009 | 08:49 PM
bud-weis's Avatar
bud-weis
Football Cwazy
are the numbers up either side of the graph the same? i.e. is 350bhp (or whatever) in line with 350lb/ft?
Old Jun 18, 2009 | 08:51 PM
AlexF's Avatar
AlexF
yes if the torque and bhp scales are equal
scoooby slayer
no mate just looked its from my new car and just noticed they pass at 7000 rpm ?
Old Jun 18, 2009 | 08:56 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Different scales, so they won't cross at 5252.
Old Jun 18, 2009 | 09:29 PM
cjwood555's Avatar
cjwood555
...but should be the same value at 5252
Old Jun 18, 2009 | 09:47 PM
dojj's Avatar
dojj
Resident Wrestling Legend
they are roughly the same values at 5252 so it looks fine
jammerrs's Avatar
jammerrs
why would they cross there exactly?
Old Jun 18, 2009 | 09:48 PM
COS 22's Avatar
COS 22
pete mcrash will know the answer !!!!!!!!!!!!!!!!!!!!!!!
rolling road guru !!!
Old Jun 18, 2009 | 09:57 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
469 bhp at the wheels, nice
This the one with the spun shells or whatever? Be great when it's back up to speed again, should absolutely fly.
Si
Old Jun 18, 2009 | 09:58 PM
RWD_cossie_wil
Because Power (BHP) is a function of Torque. The only thing you can measure is the torque of an engine, power is a calculation of torque vs speed/work done. the 5252Rpm exists because of the calculation.
Have a google search for the equasion, will explain it better
Old Jun 18, 2009 | 10:28 PM
scoooby slayer
Si
yeah mate booked in with tweenie rob 1st of july engine out and sump off and see whats going on. ive got a rod so most it should be is new crank and rod and oil tomei oil pump and away about £3.5k lighter doesnt sound bad at all though so im hopeful it isnt to bad yet.
Old Jun 18, 2009 | 10:57 PM
AlexF's Avatar
AlexF
3.5k ??
I'll do it for less heheheh
Old Jun 18, 2009 | 11:36 PM
yappstar's Avatar
yappstar
You asked....
OK, if HP = RPM x TORQUE ÷ 5252, then where does the 5252 come from?
By definition, POWER = FORCE x DISTANCE ÷ TIME
Using an example above (not displayed here on PF), where a constant tangential force of 100 pounds was applied to the 12" handle rotating at 2000 RPM, we know the force involved, so to calculate power, we need the distance the handle travels per unit time, expressed as:
Power = 100 pounds x distance per minute
OK, how far does the crank handle move in one minute? First, determine the distance it moves in one revolution:
Distance per revolution = 2 x π x radius
Distance per revolution. = 2 x 3.1416 x 1 ft = 6.283 ft.
Now we know how far the crank moves in one revolution. How far does the crank move in one minute?
Distance per min. = 6.283 ft .per rev. x 2000 rev. per min. = 12,566 feet per minute
Now we know enough to calculate the power, defined as:
so
Power = 100 lb x 12,566 ft. per minute = 1,256,600 ft-lb per minute
Great, but how about horsepower? Remember that one horsepower is defined as 33000 foot-pounds of work per minute. Therefore HP = POWER (ft-lb per min) ÷ 33,000. We have already calculated that the power being applied to the crank-wheel above is 1,256,600 ft-lb per minute.
How many HP is that?
HP = (1,256,600 ÷ 33,000) = 38.1 HP.
Now we combine some stuff we already know to produce the magic 5252. We already know that:
TORQUE = FORCE x RADIUS.
If we divide both sides of that equation by RADIUS, we get:
(a) FORCE = TORQUE ÷ RADIUS
Now, if distance per revolution = RADIUS x 2 x π, then
(b) distance per minute = RADIUS x 2 x π x RPM
We already know
(c) POWER = FORCE x DISTANCE per minute
So if you substitute the equivalent for force from equation (a) and distance per minute from equation (b) into equation (c), we get:
POWER = (TORQUE ÷ RADIUS) x (RPM x RADIUS x 2 x π)
Dividing both sides by 33,000 to find HP:
HP = TORQUE ÷ RADIUS x RPM x RADIUS x 2 x π ÷ 33,000
By reducing, we get
HP = TORQUE x RPM x 6.28 ÷ 33,000
Since
33,000 ÷ 6.2832 = 5252
Therefore
HP = TORQUE x RPM ÷ 5252
Note that at 5252 RPM, torque and HP are equal. At any RPM below 5252, the value of torque is always greater than the value of HP; Above 5252 RPM, the value of torque is always less than the value of HP.
I hope that makes some sense.
Old Jun 18, 2009 | 11:38 PM
yappstar's Avatar
yappstar
Also if the units of power and torque aren't in BHP and lb/ft they won't cross at 5252rpm
Old Jun 19, 2009 | 08:09 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
bloody hell yappstar. that is some explanation
Old Jun 19, 2009 | 12:32 PM
JonnyBravo's Avatar
JonnyBravo
The power of Google !
Good explanation though
Old Jun 19, 2009 | 03:17 PM
yappstar's Avatar
yappstar
Thanks
I got it from http://www.epi-eng.com its a VERY good site.
Old Jun 19, 2009 | 05:29 PM
Fast Guy's Avatar
Fast Guy
Originally Posted by yappstar
You asked....
so
We already know
By reducing, we get
Since
Therefore
You know you could have just said............
Therefore if rpm =5252
HP= 5252xtorque/5252
Therefore
HP = Torque at 5252rpm
Old Jun 19, 2009 | 08:42 PM
jammerrs's Avatar
jammerrs
thanks
Old Jun 19, 2009 | 08:44 PM
jammerrs's Avatar
jammerrs
Therefore
im glad you put that, that was all abit confussing for me
but thanks anyway yappstar
Old Jun 19, 2009 | 08:56 PM
Miller 3's Avatar
Miller 3
Tweeny Rob mapped my mates evo' sound guy by all accounts
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DavidK
Sep 27, 2015 02:55 PM
Marv888
Sep 26, 2015 03:44 PM
