has there ever been a car that ran an opposed piston engine?
Jun 17, 2009 | 07:42 PM
as above, a bloke at work work talking about them today and they sounded like quite a clever idea, to me
Jun 17, 2009 | 07:43 PM
Jun 17, 2009 | 07:46 PM
an apposed piston engine doesnt have a cylinder head, just a a block with a crank at both ends, fuel, air and ignition is entered in the middle as the two pistons come towards each other, if that makes sense?
Jun 17, 2009 | 07:47 PM
Horizontally opposed? Boxer engine?
Jun 17, 2009 | 07:48 PM
he means with pistons facing each other
iirc one of the autounion cars did...
Jun 17, 2009 | 07:50 PM
early train diesel are similar design
Quote:
Originally Posted by
jacko
Aye ... I posted 12 seconds after he did
Never heard of an engine like that .. I could imagine a 2 stroke that works that way.
Jun 17, 2009 | 07:51 PM
Dark-Horse
Jun 17, 2009 | 07:52 PM
Jun 17, 2009 | 07:55 PM
Thanks ... I know what a Boxer engine is ..
Come on then .. lets see some exmples?
designed in the early 1900's IIRC thought these were only made for diesel fuel tho?
Twellsie
What did you think was clever about it?
Sounds like a crap idea to me,lol.
Jun 17, 2009 | 07:59 PM
Nice pic Twellsie ..
Looks aircooled and has reeds instead of Valve's?
Jun 17, 2009 | 08:02 PM
could be a 2 stroke quite easily then with no valves
, but I would imagine the stroke would have to be very short or the compression ratios would be mad!
Dark-Horse
the above are not boxer engines, boxers have the crank in the middle and the pistons outbound
Jun 17, 2009 | 08:05 PM
RWD_cossie_wil
but i imagine you can run masive compression ratios, as there are no cylinder heads/gaskets to worry about
Twellsie
A true Boxer engine has the pistons being pushed towards each other as in 2 boxers fighting.
Boxer has been mis-used to describe flat engines.
Jun 17, 2009 | 08:06 PM
Twellsie
As stated mate ... Boxer engine has crank in middle ..
Like a porker Flat 6
Jun 17, 2009 | 08:16 PM
focusv8
no mate, this is a boxer engine
mot to be confused with the 180° V-engines
Jun 17, 2009 | 08:17 PM
Resident Wrestling Legend
at first i thought he was on about steam engines, they work like that, one piston but 2 ends when they thought of the design to make use of the extra steam
but this looks like something totaly different
Jun 17, 2009 | 08:18 PM
focusv8
Dark-Horse
which is wht he was saying
Jun 17, 2009 | 08:22 PM
dojj
Or Horizontally opposed.
The engine Twellsie was on about is summit totally different? 180* V
Jun 17, 2009 | 08:24 PM
Twellsie
This will be the infamous Boxer variant where the right hand piston has a 17mm stroke and the left hand one has a 29mm stroke, due to the right hand conrod running on the eccentric crank centre line.
Jun 17, 2009 | 08:25 PM
Dark-Horse
you are confussing the hell out of me here
Jun 17, 2009 | 08:27 PM
Twellsie
Still ultimately limited by PCP and the quality of fuel being used etc.... the normal rules would still apply.
Jun 17, 2009 | 08:31 PM
Twellsie
As far as iam aware a Boxer or Horizontally opposed engine has the crank in the middle. Flat engine found in porkers.
The one you described (with Pics) I've never seen before ... I never went to
The history of Engine class.
Got to hand it to you: Pretty interesting thread ... The replys came to fast and some got mixed up
Jun 17, 2009 | 08:42 PM
Dark-Horse
I am pressuming that is the difference between a Horizontally opposed engine and an opposed piston engine?
like the fairbanks morse opposed piston deltic
Jun 17, 2009 | 08:45 PM
Twellsie
Yeah .. I supose
Changed a timming belt on one of those the other day
EDIT: Do'H It didnt have a timming belt
Twellsie
holy shit what did that power
Jun 17, 2009 | 08:50 PM
rs-tuner
over 3000bhp apparently
Jun 17, 2009 | 08:52 PM
lol, the question was what did it power, not what power did it make.
answer to your question, trains and boats
Jun 17, 2009 | 08:53 PM
deltics now were talking..................
Jun 17, 2009 | 08:58 PM
Wiki is a wonderful thing
Are they still in use?
No wonder your mate get's a stiffy on over them ..
Jun 17, 2009 | 09:04 PM
Dark-Horse
I dont think he gets a stiffy over them
we where just talking about engines, lol
Jun 17, 2009 | 09:07 PM
Twellsie
No worries ... I use to get stiffys over MTU's And QSK's
Bet they churn out horrendous emission.
Jun 17, 2009 | 09:13 PM
Dark-Horse
i have no idea what they are
Jun 17, 2009 | 09:20 PM
Hi all,
Some 1960's Commer truck's used a 3 cylinder opposed piston 2 stroke supercharged diesel, that had a single crankshaft at 90 degree's to the cylinder's and below them, the piston's had conrod's connected to rocker arm's that had another set of conrod's connecting to the crankshaft !
This engine was known as a "Commer screamer" as it had a great sound.
Other than a rotary engine this was the last "unusual" type of engine on our road's.
The Deltic engine was made by Napier.
Andy
Reason: Added picture
