esc cos alternator tensioner pulley noise
Old Dec 11, 2004 | 02:17 PM
ajjames's Avatar
ajjames
Default esc cos alternator tensioner pulley noise
as above it is a 1995 esc cos with the multi v belts and i cant stop the tensioner squeeking i have replaced the tensionerpulley which cures the problem for about five minutes and the squeek comes back so i then bought a new bearing for it and fitted it and it did the same again i dont know what else to do what could be causing these bearings to fail after such a short time any help on ideas appr echiated
Old Dec 12, 2004 | 09:49 PM
Monte 76's Avatar
Monte 76
Are the belts set too tight causing undue strain on the bearings?
Old Dec 13, 2004 | 06:53 AM
Escort cos's Avatar
Escort cos
Is it definately the tennsion pulley, as mine is doing the same and it sounds like it's coming from the back bearing on the alternator, which dries out being near to the turbo.
Old Dec 13, 2004 | 07:37 AM
ajjames's Avatar
ajjames
i have bought a stephoscope which has a long bar on the end of it and every thing is quite apart from the tensioner which has an automatic tensioner but i will check the rear alternator bearing again cheers for the ideas
jonfoc
16
Sep 11, 2018 05:35 PM
Nov 1, 2015 06:53 PM
gingeRS
17
Oct 2, 2015 09:42 AM
dombanks
Sep 21, 2015 08:38 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
