alcon 6 paddle clutch
Old Jun 16, 2009 | 11:28 AM
mechanic28's Avatar
mechanic28
Default alcon 6 paddle clutch
Had one of these in my 2wd cossie for around 18 months done no more then 2000 miles its now starting to smell when you give it some do not think its slipping yet but do not think it will be long power is around 360 maybe 370 odd has heavy duty cover and i got the flywheel resurfaced when i fitted it!anyone else had one let go this quick?i do not dump it off the lights always get it rolling first!Most of the driving is done in town heard that alcon clutch do not like this?and it knocks them out quick
Old Jun 16, 2009 | 02:59 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mines still going after 4 years
Steve
Old Jun 16, 2009 | 03:38 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
had mine for over a year now-no problems
probly cos its still sat on my shelf ready to fit
this will make interesting reading for me
Old Jun 16, 2009 | 03:48 PM
Twellsie's Avatar
Twellsie
mines lasted about 6k, need a new one now though
Turbosystems's Avatar
Turbosystems
Super Moderator
Steve
but you had no boost compared with doug
Old Jun 16, 2009 | 03:56 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve
But i have some now
Steve
Old Jun 16, 2009 | 04:00 PM
Turbosystems
Super Moderator
the correct type actuator always helps steve
may the boost be with you always
Old Jun 16, 2009 | 04:01 PM
LHD220Turbo's Avatar
LHD220Turbo
should last alot longer than that by the sound of the way ypu drive
i had a second hand AP clutch it mine and it had done 3000 when i bought it and i put another 2200 miles on it
Old Jun 16, 2009 | 04:04 PM
Staffi's Avatar
Staffi
PMSL @ Tony & Steve...
Rich,
That,ll teach you to do all those Rolling Road runs...
Mine,s gone too, having an AP fitted as we speak, i thankfully changed my mind today from an Alcon to an AP... mind you, i,m only running stage 1 so could of fitted an original clutch in i guess ......
Old Jun 16, 2009 | 04:08 PM
Twellsie's Avatar
Twellsie
Rich,
we all know you too well Pete, it will either get sold or end up being highly modded, lol
Old Jun 16, 2009 | 04:10 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
But i had the correct actuator, it was my turbo
Steve
Old Jun 16, 2009 | 04:11 PM
Turbosystems
Super Moderator
paddle clutch plates are not suitable for heavy town driving
Old Jun 16, 2009 | 04:12 PM
Turbosystems
Super Moderator
Steve
so how come fitting the correct actuator fixed your boost problem ?
Old Jun 16, 2009 | 04:16 PM
Staffi's Avatar
Staffi
I,m going to suprise you all with this one Rich, infact i may even keep it a year...
Only mod if any will be the NMS Gunship mate, you know that already.....
Old Jun 16, 2009 | 04:20 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have no idea, luck ??????
Steve
Old Jun 16, 2009 | 04:25 PM
Turbosystems
Super Moderator
not luck steve you clearly have none of that
The back pressure trying to run 26 psi boost on a t3 .55 over size waste gate penny and aperture lifts it off it's seat with a -31
Old Jun 16, 2009 | 04:54 PM
JamesH's Avatar
JamesH
we all know you too well Pete, it will either get sold or end up being highly modded, and THEN sold lol
Old Jun 16, 2009 | 04:56 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Can you tell MSD that please
Steve
Old Jun 16, 2009 | 05:00 PM
xr4x4rs's Avatar
xr4x4rs
my alcon with uprated ap cover last lasted around 5-6k and also welded itself to my my flywheel
Old Jun 16, 2009 | 05:18 PM
DAN-Saff's Avatar
DAN-Saff
Had a alcon and only got over 4k miles out of it and that was on a stg3 2wd. I'm really impressed with the helix organic that i have on the esc. Went up to Turbosystems yesterday to map the car and it didn't slip that is with a t4 @ 30+psi and Tony driving.
Old Jun 16, 2009 | 07:02 PM
mark_24v_wiring's Avatar
mark_24v_wiring
So thats the real cause of the problem then?
Thought it had something to do with the actuator but steve wanted someone who knows what there doing to check it out properly for him
Old Jun 16, 2009 | 07:04 PM
Staffi's Avatar
Staffi
Originally Posted by James90RS
Shut it you............
Old Jun 16, 2009 | 07:06 PM
Stu.H's Avatar
Stu.H
I had an alcon on my zvh, was running prolly 220 max, when karl redid the engine it ran what it says in my sig and the alcon was promptly destroyed
One AP 4 paddle later, minty mint
Old Jun 16, 2009 | 07:07 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Steve
i was running 36psi on a t34, with a -31, no issues at all
Old Jun 16, 2009 | 07:09 PM
marco polo's Avatar
marco polo
persoanally i wouldn't bother with the the alcon go for the ap 6 pladdle with thier cover , you might have to go hydraulic clutch tho as these are heavy fookers and you will either snap or stretch the cable
i had an alcon yrs ago it never lasted as long as the ap one tbh
marco
Old Jun 16, 2009 | 07:27 PM
mark_24v_wiring
Was your -31 new then?
Steve's has been on the car for a while now (5 years+) and was running a full hole of preload so fitting a new -34 has solved his problems perhaps a new -31 would of had the same result but not according to Tony.
Old Jun 16, 2009 | 07:53 PM
JTECH James
Passion for Fords!
mine was on my car for 4 years, and was still perfect so ended up on my T4 aswell
Old Jun 16, 2009 | 11:23 PM
mechanic28's Avatar
mechanic28
hmm not sure then!was thinking of going over to a ap one!and pleased you listened to me steve and took it to tony at long last!bloody hard work you are!
Old Jun 16, 2009 | 11:27 PM
mechanic28's Avatar
mechanic28
what would you recommend tony?
Old Jun 17, 2009 | 08:34 AM
Turbosystems
Super Moderator
I recommend you don't do any town driving
Old Jun 17, 2009 | 01:40 PM
Yura's Avatar
Yura
hm, interesting thread... I thought to buy alcon for my 400hp sierra. Now I dont know what to buy At this moment I run with Ap organic+ford cover(SACHS) and it slip.
Can alcon now has worse quality then before? Or not heavy duty cover now in there kits?
Old Jun 17, 2009 | 01:42 PM
JamesH's Avatar
JamesH
Got an Alcon 6 paddle and standard cover, with 350bhp been in there a few yrs and done about 13k, all good so far
Old Jun 17, 2009 | 01:43 PM
Staffi's Avatar
Staffi
Tony,
It,s like driving Miss Daisy with Doug.. he doesn,t do owt else but town driving....
Old Jun 17, 2009 | 01:47 PM
Turbosystems
Super Moderator
Tony,
daisy doug
Old Jun 17, 2009 | 01:49 PM
Staffi's Avatar
Staffi
daisy doug
New username...
Old Jun 17, 2009 | 04:11 PM
mechanic28's Avatar
mechanic28
well look whos piping up no doubt you will be on another evo forum in a couple of months
Old Jun 17, 2009 | 04:12 PM
mechanic28's Avatar
mechanic28
Old Jun 17, 2009 | 04:26 PM
Staffi's Avatar
Staffi
I still do Doug, that,s why i,m so liked and popular...
You,re still a newbie here 2007....
Anyway, HAVE you got the clutch yet??
Old Jun 17, 2009 | 07:00 PM
mechanic28's Avatar
mechanic28
its amazing how quickly you can go off people aint it pete
will wait until the clutch gives out totally i think then decide still thinking of the 3 door route tho white one like yours mate eyeing one up as we speak
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
