Fiesta Mk4 Full Camber Adjustable Wishbones
Recently added to the range of our modified arms and wishbones are the Fiesta Mk 4 / 5 full camber adjustable wishbones.
Essential for improving traction on sprint cars or to re set the camber on lowered road cars to save tyre edge wear.
Other Mk3 Fiesta models are now in production (RS, non RS, 1600, 1800, PAS, non PAS etc. Pease enquire for availability and prices
- All rubber bushes removed and replaced with alloy bearing carriers
- Full race spec high quality bearings pre fitted
- Load bearing rose joints with specially strengthened pinch bolts
- +ive and -ive camber adjustments on each arm
- Complete with all joint side spacers and bearing dust covers
- Powdercoated in motorsport blue
Which ones there are several types for the Mk3
Excluding XR2i + RS models:
1989-1994 - FCA5613 + FCA5614 (with a 2 rivet balljoint fitting)
FCA5716 + FCA5717 (with a 3 rivet balljoint fitting)
1994-1997 - FCA5711 + FCA5712 (with 3 rivet balljoint fitting)
1.6 XR2i and 1.6 RS Turbo
1989-1992 - FCA5613 + FCA5614 (with a 2 rivet balljoint fitting)
FCA5666 + FCA5667 (with a 3 rivet balljoint fitting)
1.8 XR2i and 1.8RS
1992-1995 - FCA5721 + FCA5722 (with angled balljoints)
FCA5646 + FCA5647 (with straight balljoints)
1.8 XR2i and 1.8RS
What colour would you like Tim as they are all re powdercoated after being modified.
Price for the fully modified fully adjustable positive and negative camber arms would be around £225 or less if you only need the bushes replacing and the ball joint leaving as standard.
FRP arms are currently being worked on 00fergie as we received a standard FRP arm this week to use as a guide. There is a group buy / interest thread running on a few Puma forums already.
£250 plus delivery for the fully modified arms. We also have eccentric and concentric top mounts at about £80 and rose jointed track rod ends at a similar price for the 3.5
Arms are currently made to order and we are just waiting for Germany to ship over the special rose joints we use, so there is a slight delay on back orders.
Full outright purchace of new arms.
By the time we have them converted and re powder coated if ordered now, we are hoping the rose joints will be here, so should go out in the usual 10 - 14 days time from date of order.
Hi tony tried to pm toy but your inbox is full... Do you guys still make these? Looking to buy some asap. Do you have them in stock?
Danny
Danny
Marc sierra
12
Aug 30, 2015 10:38 AM
track.focus'd
Aug 12, 2015 05:53 PM
adjustable, adjusters, adjusting, adjustment, arms, bottom, camber, fiesta, ford, front, mk4, motorsport, race, wishbone, wishbones
