advice ; doing rear suspension bushes on a Fiesta mk5
Old Jun 12, 2009 | 05:04 PM
rallycross's Avatar
rallycross
Default advice ; doing rear suspension bushes on a Fiesta mk5
how much is it likely to be to do;
the bushes on the rear suspension (where the rear axle is bolted to the floor, in front of the rear wheels)
2001 fiesta.
thanks
Old Jun 12, 2009 | 08:38 PM
rathbone's Avatar
rathbone
i paid £50 for polyflex bushes just undo the eight bolts holding the beam up then lower the beam and remove the mount then burn the centre out and chisel out the rest after that clean it all up then grease and push in the new bush followed by steel insert and refit
TrevCos
Aug 17, 2015 09:08 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
turbobill
Aug 1, 2015 08:55 PM
