blacks or greys..??
Old Jun 11, 2009 | 05:08 PM
an1mal_69's Avatar
an1mal_69
Default blacks or greys..??
my other post got swamped without any real info & i cant find much searchng.
whats the pro's and con's between the 2..??
Old Jun 11, 2009 | 05:30 PM
benporter's Avatar
benporter
no pros and cons realy imo just use greys up to 420 them move to blacks depends what you want/already have
Old Jun 11, 2009 | 05:32 PM
LHD220Turbo's Avatar
LHD220Turbo
greys arent made anymore Blacks are
Blacks is newer technology
83lb blacks are a circa 500bhp injectors, greys are not
"apparently" Blacks have a better spray pattern, but not seen evidence of this personally
Blacks need no fitting kit
there is nothing wrong with greys, its just that blacks are newer, and are the choice of many of the big tuners
Matt
Stu @ M Developments's Avatar
PassionFords Creator
Siemens. Cheaper, fit straight in with no fitting kit, bigger.
No brainer IMO.
Old Jun 11, 2009 | 05:45 PM
AndyPen's Avatar
AndyPen
No brainer IMO.
Do they (blacks) map easier if you don't mind me asking Stu?
I have some here so was wondering about changing the greys for them.
Cheers,
Andy
Old Jun 11, 2009 | 05:49 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
dont forget in the "cossie" world.....blacks = 55lbs, 72lbs, 83lbs.......55's are bigger than greys.....
Old Jun 11, 2009 | 08:44 PM
AndyPen's Avatar
AndyPen
The ones I have are 83lbs I believe, how can you check?
Old Jun 11, 2009 | 09:00 PM
LHD220Turbo
it will have a 4 digit number on the side of the injector
3102 = 55lbs
3145 = 72lbs
3105 = 83lbs
Matt
Old Jun 12, 2009 | 06:52 AM
bad boy rs's Avatar
bad boy rs
i have greys on my saph runs sweet no complaints from me
Old Jun 12, 2009 | 08:08 AM
Cheers,
Andy
Presuming you mean the most comparatively sized ones which are the 55s, then absolutely no difference whatsoever mate.
Old Jun 12, 2009 | 08:53 AM
There's nothing wrong with greys, they are a perfectly fine injector, though as said production will NOT be resumed on these.
The greys or 0 280 150 403 are still about, though not many new ones it has to be said.
There are 3(three) in the UK, and 1000 in Germany today.
It's certainly not worth swapping just for the sake of it, but obviously if buying new then I personally would go for an alternative to the greys, but up to each to decide, not sure which ones I'd go for make wise.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
