spring rates for "fast road" use
Old Jun 11, 2009 | 04:18 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default spring rates for "fast road" use
what are people using on there Gaz coilovers for an everyday 4x4 saff.....at the mo i've got 325 front and 175 back........sick of them, was going to change the front to 275's...........help.....
Old Jun 13, 2009 | 06:57 PM
pete mcrash
up..............fuckerzzzz
Old Jun 17, 2009 | 04:14 PM
pete mcrash
i've got ne mates..........
Old Jun 20, 2009 | 07:11 PM
pete mcrash
i'll keep trying........
Old Jun 20, 2009 | 07:16 PM
dave cos4x4's Avatar
dave cos4x4
would you notice the difference though?
not sure you would.
Old Jun 20, 2009 | 07:21 PM
pete mcrash
yeh.....i got a reply..........not a good one but yeh.................(apparently yes Dave)
Old Jun 20, 2009 | 07:22 PM
dave cos4x4
give it a go then, cannot be that much for a set of springs.
Old Jun 20, 2009 | 08:01 PM
pete mcrash
.....only £50...........
Old Jun 20, 2009 | 11:27 PM
DazC's Avatar
DazC
all i can suggest is try it. Personal preferance and all that.
I'm on 170 on the rear and 300 on the front on a series 1. It's a bit hard but i prefer not having the body roll.
Old Jun 21, 2009 | 08:44 AM
You are going to have serious trouble running just 175 on the rear unless you massively whack up the bump/rebound it will bottom all over the place way too soft.
I run 200lb" on the rear and that is too soft.
Old Jun 21, 2009 | 09:43 AM
pete mcrash
......we've already talked fella........u've got me thinking....maybe i should stiffen up the rears and leave the fronts......maybe thats my problem........
the front is solid and the back does wobble about, so i turn the back up to compencate....and it just isn't right........
Old Jun 21, 2009 | 11:43 AM
It won't be, as when you adjust rears it is usually both the bump and rebound that is adjusted, whereas in a ideal world for you just the bump would be better on the rear.
If you stiffen the rear it will have the effect of softening the front a bit, just try it.
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
L1AM_RS
Sep 23, 2015 03:27 PM
truffleshuffle
Sep 10, 2015 09:35 PM
