200 BHP @ fly
Old Jun 9, 2009 | 11:24 PM
T28 RST's Avatar
T28 RST
Ok then
Default 200 BHP @ fly
Whats your mods
I await the usual
Genuine mods you think that make the magical 200 @ fly
Old Jun 10, 2009 | 12:00 AM
T28 RST's Avatar
T28 RST
Ok then
Chip
Exhaust
Filter
Wont do it
Old Jun 10, 2009 | 12:51 AM
jamieRST's Avatar
jamieRST
T28 what do you think i could achieve running the following:
1.6 cvh
bmc air filter
2.5"exhaust system
farndon steel rods
accralite forged pistons
7.5.1 compression
kent cvh34 cam kit inc vernier pulley
uprated valve springs
stage 2 head
s/s manifold
T25 turbo
uprated plugs + leads
ap organic clutch
lightweight flywheel
cts stage 2+ box
running on emerald management
above is not all of the mods obviously,just a rough idea,am after more torque than bhp
Chopshop85's Avatar
Chopshop85
There was a guy on here who got 191bhp from a "completely stock" engine apparently. Must be some sort of tuning god.
Old Jun 10, 2009 | 07:15 AM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
1.6 cvh
bmc air filter
2.5"exhaust system
farndon steel rods
7.5.1 compression
stage 2 head
s/s manifold
T25 turbo
ap organic clutch
cts stage 2+ box
my guess is about 200 - 240 with the ts5, put a t3 or bigger with 380cc+ injectors on it and 250+ easiliy (only my estimate though )
Old Jun 10, 2009 | 07:23 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Originally Posted by T28 RST
Whats your mods
I await the usual
I'm not there myself yet
But IMO...
Chip
Air Filter
Exhaust
Stage 2 T3
-31 Actuator
FMIC
Old Jun 10, 2009 | 07:33 AM
user 769729789's Avatar
user 769729789
But IMO...
Chip
Air Filter
Exhaust
Stage 2 T3
-31 Actuator
FMIC
Probably not far away at that, my spec was as follows
Pace fmic
Turbosystems ECU
Turbosystems stage 1 Turbo
Collins -31 Actuator
Pipercross filter
3.5" Straight through system
Along with the usual DV and 15psi it made 164bhp atw at AVA which must be about... 195bhp atf? maybe.
Old Jun 10, 2009 | 09:33 AM
cabrst's Avatar
cabrst
David you know my spec and i got 148bhp @wheels on 0.7 bar
Old Jun 10, 2009 | 09:50 AM
orionmojo's Avatar
orionmojo
so what can be deducted for transmission loss (in rough terms obviously)
i.e if you aim for 200 @ the wheels, what could that be at the fly?
when i talk about hp figures i mean the wheels. is that the general way to go? or does everyone else quote flywheel figures?
i never thought about my pub bragging rights - Joking btw
my spec is.
std bottom end, balanced flywheel.
nms stage 2 head - new standard cam
-31 actuator. unknown turbo. 1 bar boost
nms chip
k&n panel filter in chopped airbox
straight through exhaust, backbox only
std intercooler
i think thats it.
i was thinking 170-175 at the wheels, looking to 180-185 with an FMIC
is that realistic?
Old Jun 10, 2009 | 09:54 AM
Alps Pacino's Avatar
Alps Pacino
A mate of mine years ago blew his motor up so bought a brand fire new engine from ford, he also bought a brand fire new turbo and metering unit while he was on with it. Mods wise he had the usual chip, filter and exhaust and a forge double capacity intercooler and that made 196bhp, was an absolute flying machine back in the day and was way quicker than the rest of the rst's about. I aint saying the figures are correct before anyone shoots me down in flames but it was quick as fuck for the mods it had
Old Jun 10, 2009 | 10:08 AM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
I would say, fmic, bayjoo chip, -31, filter, exhaust, and imo either kent, piper, or newman cam, or stage 2 turbo would give you around them figures imo
Old Jun 10, 2009 | 12:50 PM
Karlos G's Avatar
Karlos G
Balls Deep!
my spec is.
nms chip
std intercooler
i think thats it.
is that realistic?
Most people talk about @fly but really we should all talk abotut @wheels as this is what counts!
Transmission loss for a FWD is roughly 15%, so your 200@wheels is about 230@fly
Old Jun 10, 2009 | 01:13 PM
orionmojo's Avatar
orionmojo
ah cool. cheers for that.
Old Jun 10, 2009 | 01:21 PM
grayzo's Avatar
grayzo
grayzo
my car is 206bhp at the fly wheel on mfi with a ported polished and gas flowed head kent cvh 34 and pulley stage 2 t3 turbo radtech front mount and turbosystems ecu chip and i make this power at 17.5 p.s.i
Old Jun 10, 2009 | 01:35 PM
PaulT's Avatar
PaulT
Whats your mods
I await the usual
And the point of this question is ?????
Its all well and good saying i have this you have that etc its only a number on a graph drive it and enjoy it and stop chasing numbers because at the end of the day thats all it boils down to.
PaulT
Old Jun 10, 2009 | 03:33 PM
gaz s1's Avatar
gaz s1
1.8 zvh
Stage 3 head
Pe cam
tt stage 2 turbo
18 psi
pro alloy front mount.
not been set up yet but hopefully should break the 200
Old Jun 10, 2009 | 09:15 PM
T28 RST's Avatar
T28 RST
Ok then
PaulT
Its only a question mate that gets asked alot of times on here
Seeing the answeres gives people different ideas and also gets people thinking about what they need, etc...
Old Jun 10, 2009 | 10:07 PM
Matt-Turbo's Avatar
Matt-Turbo
T34 turbo
2.0 zetec bottom end
efi
cossy managment
biegh injectors
front mount
exhaust system
I only have it ran it wat do you think il be gettin when i get it set up?
Old Jun 11, 2009 | 11:20 AM
RabReith89's Avatar
RabReith89
Engine has piper 285 cam and pully, new followers, reground crank new bearings, stage 2 chip, airtec single pass intercooler, airtec alloy radiator, airtec turbo cooler, stage 2 hybird turbo, new k&n 57i induction kit whit air fed hose, magnecor kv85 ht leads, ngk spark plugs, full samco hoses, full mongoose system, manifold heat raped as well as down pipe, new bailys dump valve.
Wont know of real bhp till next friday.
Old Jun 11, 2009 | 10:35 PM
MunkeyboyRS's Avatar
MunkeyboyRS
Bananas!
I think I'm running 191.8bhp @ fly
Green Filter
Airtec intercooler
Superchip
S/s exhaust
-31 actuator
and 16psi of boost.
Well this is as far as I know, I have a rolling road print out from the old owner in 2007 at that spec. As of yet I'v not had a chance to get on a rolling road yet.
I do know that my tow best mate, one has a Mr2 turbo and the other Pug 306 gti6, both played with, I leave the both of them for dust.
Old Jun 13, 2009 | 12:18 PM
DanRSturbo's Avatar
DanRSturbo
Power Engineering Stage 1 Chip
K&N 57i induction Kit
Mongoose 2.5" system into 4" tailpipe
Pace Chargecooler
AP Organic Clutch
CTS Stage 1 gearbox
Samco boost hoses
Nov 1, 2015 06:53 PM
chowfornow
Alloy wheels and ICE for sale
15
Oct 17, 2015 07:09 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
Marv888
Sep 26, 2015 03:44 PM
