rough idea on price..??
Looking to get some 55lb siemens & a new chip for mine, gonna put my dk greens and current chip on fleabay, but what kind of money do they go for, best to put a buy it now or let the auction run with a reserve..??
just doing a little more research on this, whats the pro's and con's between the siemens & the grey's..??
I noticed on Stu's listing he rates the siemens from 360-380 an the greys at 380. Also the listing with the greys specs a larger I'cooler where as the siemens does not..??
my current spec is; 2WD with 1mm bore on 200 block, T34.63, FMIC, stock cams, 803 injectors, MSD chip to suit, swirl pot and breather etc. Running around 20psi at the mo'
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Orion_Gav
Sep 29, 2015 04:50 PM
