2wd driveshafts on a 4wd rear end ?
I have a 7.5" rear diff which I want to mount on my 4wd saph cosw rear end, is it possible using the 2wd rear drive shafts or won't that fit the rear arms ?
Thanks for your help !
not just that, the pcd of the 2wd diff is 108mm
the pcd of the 4wd cars is 100mm
so none of the holes line up as the cv's are different sizes
easier to just get a 2wd rear end set up in the first palce than have to chop the 2wd diff about
jessie_rs
11
Jun 3, 2019 04:57 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
track.focus'd
Aug 12, 2015 05:53 PM
