Advice when looking at Focus RS
Old Jun 7, 2009 | 06:16 PM
Tev's Avatar
Tev
Default Advice when looking at Focus RS
Right guys/gals I need some advice on what to look out for on 02/03 plate focus rs's
Just really need to know what to look out for, any weak points bodywork/mechanical, where to look for signs of rust etc
basically I know next to nothing about them and just need some tip's on what to look out for.
Ta
Old Jun 7, 2009 | 06:49 PM
thebigmacmoomin's Avatar
thebigmacmoomin
There are Phase 1 and 2 Focus RS's. The 2 had better stiching on the seat bases and something about a pink throttle cable (?????). Rather dissapointingly there is no heated front screen. Ford were rather stinggy with the spec on the RS.
Below taken from FFOC forum.
Something done by Ben aka Purple pants off RSOC, been useful for a few people including me
Outside the car
-check all the wheels for kerbing
-check to how the tyres are wearing, they should wear more on the inside. if they don't the tracking needs doing. Also check the tred as that will be another £260 upwards
-check the brake discs and pads too. Feel the face of the discs to see if there is a lip.Stick your finger round the back of the disc and feel too. this would cost £300 if the pads and Discs need changing.
- see if the body work is dented/scratched. If its dry get down eye level with the car and check for dents. it will have swirls and a few marks as its a 2nd hand car. just worry about bad ones.
-look under the front bumper for scuffs and make sure the under tray is there check the bumper for cracks. £400 for a bumper!
-dont worry about stone chips this is normal as the paint is very soft.
-the paint should look orange peely if its standard paint and the rear quarters should look wavy as they are all like it
-look inside the door shuts and boot for over spray.
ask if its been in any accidents
Engine
-dont worry if its sounds tappy. they all do.
-ask what oil he uses. should be 5/40 or 5/30.
-Ask what fuel he uses. If he uses normal fuel. Walk away! it must have 97ron in it. ie super unleaded/vpower
-check there is a white shield over the turbo at the front near the slam panel. if this is missing its another £80.
-next to the brake reservoir is the chargecooler reservoir. when the engine is running take the lid off and make sure there is a stream of water squirting out of it. if there Inst. ask when the last time he check it was. if its more than a day walk away. this not working can cause serious damage.
-check the thermostat housing for pink crusty stuff around it (this is in front of the coil) if this is leaking thats another £50.
-look at the coolant tank. if it looks cloudy. possible head gasket failure.
look under the oil cap for a creamy/mayonnaise gunk. this means the head gasket has gone. walk away
-when the car has been driven and is warm. One of you rev is up to 4k the other one watch for smoke. A puff when you back off is fine as long as it black. anything else is going to be expensive.
-when the cars warm. put it into 4th raise the revs till 2k rpm. then lift the clutch it should stall if it doesn't the clutch is slipping. this will cost £500.
-drive the car slowly and turn the wheel quite far. like your driving out of parking space. listen for a knocking. this could cost you upto £150
- The boost if its standard should hit the white and then back off. test this is 3rd gear. it should be at full boost by 3000k RPM. If its miss fires/holds back when you accelerate at 4000 to 5000RPM dont worry this is the MAP it can be sorted.
-check the chassis number with the number on the side of the head. make sure they match.
Inside the Car.
-Dont worry about creased seats. just check for tares and rips.
-check the carpet on the passenger side nearest the centre of the car at the top to see if its wet. its its soaking you make need a new carpet. about £100. plus pollen filter and seal
-check the steering wheel for wear. £130 if its worn alot. the blue normally comes off.
-Check the boot well, for water. make sure its not rusty.
-make sure it has the RS leather Wallet with it. If it hasn't knock him down £100.
-make sure it has a full service history with receipts.
All the prices above are ford prices and parts can be got alot cheaper on the rsoc so dont worry to much about running/ servicing costs then obviously all the usual stuff when buying a car
Andy
Old Jun 7, 2009 | 07:45 PM
Tev's Avatar
Tev
thats fantastic
cheers Andy thanks for your help fella
Old Jun 8, 2009 | 12:12 PM
Doncarlyon's Avatar
Doncarlyon
No such thing as phase 1 or 2... that was made up by EVO magazine.
Old Jun 8, 2009 | 12:31 PM
gramsey's Avatar
gramsey
your right, but its a good guide for people to follow to know what they are looking for.
Old Jun 8, 2009 | 04:26 PM
binman jim's Avatar
binman jim
i thought the standard rs is mapped for 95ron not 97ron
Old Jun 9, 2009 | 11:42 AM
Doncarlyon's Avatar
Doncarlyon
97ron
Old Jun 9, 2009 | 03:11 PM
binman jim's Avatar
binman jim
97ron
i swear when fast ford did a full write up on the focus rs it said it was mapped for 95ron
Old Jun 9, 2009 | 06:56 PM
AlexRS2782's Avatar
AlexRS2782
No they didn't
The article stated that using Dreamscience software Pumaspeed were able to create a custom engine map enabling the car to run on 95ron fuel - however this was effectively achieved by turning down the boost & running less power so the car could run the lower ron fuel without damaging the engine
As standard, from the factory, the Mk1 FRS requires, and is designed to run on, 97+ ron fuel
Old Jun 9, 2009 | 07:03 PM
thebigmacmoomin
I know there arnt, but the later ones did have a few changes. So kinda a Phase 1 and 2.
Andy
Old Jun 9, 2009 | 07:13 PM
AlexRS2782's Avatar
AlexRS2782
TBH it's been proven on the rsoc that the phase 1/2 is balls tbh - it only came about as Evo thought it was the easiest (but wrong) way of differentiating an early build car from a late build car when buying used, however there are loads of early registered FRS (call them Phase 1 if you like) that over the first 3 years of their life have been retrofitted with the so called later "Phase2" items - things like the pink throttle grommet, stitched seats, ae/af engine maps, as they could all be done by Ford under service & warranty
Old Jun 10, 2009 | 11:08 AM
Lami's Avatar
Lami
Andy
Originally taken of the RSOC, Write up done by Minimadgriff
Old Jun 10, 2009 | 08:16 PM
binman jim's Avatar
binman jim
Originally Posted by AlexRS2782
No they didn't
cheeRS for that. atleast thats an explanation. couldnt really be asked to go 95ron-97ron-95ron-97ron all day.
Old Jun 11, 2009 | 06:18 PM
thebigmacmoomin
You didnt read the 1st line of the quote then ?
Andy
Old Jun 27, 2009 | 09:05 PM
f6cus's Avatar
f6cus
the above check list was a massive help to day while looking at focus rs and as a result i ended up buying a good one
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
