Rock hard brake pedal
My 2wd saff has one solid brake pedal, you can blow on the pedal and it will nose dive!
you can also hear the ABS making lots of noises like clicking, it pulls to the left under braking and sometimes the ABS light comes on
What can this be? the ABS unit it self or the discs?
weird..as yday after half an hours worth of driving my pedal just got rock solid too..no lights came on got in the fecker this morning and all is fine again..sorry this post is not much help.
thanks for the replies
i dont think its a siezed caliper, although i will not rule that out. The ABS system is making a lot of noise even when not braking and idling etc
I re read your post, I would check the rings on the wheels to make sure they have nice distinct gpas between the segments, and are not covered with rust, maybe the abs is spassing out not being able to read/compare the speed of the wheel.
SMILER258
Sep 28, 2015 09:04 AM
