removed heater blower
Old May 29, 2009 | 04:12 PM
16vzetec's Avatar
16vzetec
Default removed heater blower
wanted some more space under bonnet to gain room for throttle bodies.
removing the heater blower and cowling is easy but then your left with engine fumes blowing in all the time which sticks the cabin out.
so i made a cover for the hole and fitted a pipe into it that runs infront of my rad so its constantly blowing air in unless you shut the vents off.
the hot and cold lever still works fine.
its made alot more room under the bonnet and has shed some weight too .
just got to make a rain catch tray under the rear bonnet grill which i am now using as a bonnet vent.
before;
during;
after;
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
