how easy is it to connect pc to lcd tv
Old May 29, 2009 | 03:36 PM
turbolee's Avatar
turbolee
Default how easy is it to connect pc to lcd tv
i want to run my pc on my lcd tv i have a d sub socket on tv is this how i connect tv to pc what leads do i need how do much do they cost thanks
Old May 29, 2009 | 03:57 PM
kitted_escort's Avatar
kitted_escort
im not sure how much they cost, have a look at the argos web site, probs have them in there some where, or go to pc world.
i think the lead plugs in where the monitor norm does then plug the other end in your tv
Old May 29, 2009 | 04:16 PM
ballin's Avatar
ballin
easy, takes 2 seconds and about 50p!
Picture won't be great though
Old May 29, 2009 | 08:32 PM
DanRSturbo's Avatar
DanRSturbo
Has your TV got got a monitor input on it same as a graphics card on a pc ?
Old May 29, 2009 | 09:43 PM
turbolee's Avatar
turbolee
it has a d sub socket and a pc audio socket
Old May 29, 2009 | 09:58 PM
SS1's Avatar
SS1
check your tv specs then you pc specs maplins is your best bet
http://www.maplin.co.uk/Home.aspx
click on the computing on there site task bar
Old May 29, 2009 | 10:03 PM
SS1's Avatar
SS1
this may help you read the thread you can buy a Y SPLITTER cable
http://www.techsupportforum.com/home...t-problem.html
Old May 30, 2009 | 10:07 AM
AC555's Avatar
AC555
If you have a VGA out socket on your PC (i think theses are d sub type) and a VGA input socket on your tv you can easily connect using a VGA Monitor cable;
They are around £20, but shop around you can get em cheaper. Make sure you check them carefully as there are different types. PC world and maplin do them. Audio input on TV is usually just a 3.5mm Jack direct from output on PC.
As for the quality on a LCD TV its top notch
Andrew
Old May 30, 2009 | 11:49 AM
turbolee's Avatar
turbolee
ok thanks for that guys i will sort my cables and see how it goes
Old May 30, 2009 | 12:38 PM
Thrush's Avatar
Thrush
Irritating c........
I connected my media PC to my TV (plasma) using a standard VGA cable. The PC is super shit spec and has only a proper basic graphics card in it and yet I was able to get full 1920x1080 resolution and it's clear as crystal!
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
jc1989rs
Sep 18, 2015 07:05 PM
