Simple question, 2wd sierra cosworth front discs to s2 rst. how?
Old May 27, 2009 | 07:52 PM
Antti O's Avatar
Antti O
Default Simple question, 2wd sierra cosworth front discs to s2 rst. how?
I am pretty sure i have std front discs bend and fucked because brakes shaking steering wheel.
Where i can buy some brackets for sierra cosworth 2wd front discs & std rst calibers?
Do these fit under 15" std rst alloys?
Old May 27, 2009 | 07:59 PM
mark2's Avatar
mark2
Where i can buy some brackets for sierra cosworth 2wd front discs & std rst calibers.
hi
hi spec sell the hole kit brackets/bolts/washers/discs
have you checked the rear brakes as the adjusters sieze and a knackered wheel cylinder causes braking shudder and poor braking ,worth a try/elimination
mark2
Old May 27, 2009 | 08:03 PM
mark2's Avatar
mark2
i would go cozzie disc and calipers just like the thread on brake upgrade i have used both set ups and even thou cozzie disc and brakets /standard rs calipers are an improvement all cozzie set up is even better
mark2
Old May 27, 2009 | 08:11 PM
Antti O's Avatar
Antti O
237£ + cargo to Finland sounds pretty much to me? 260mm Std discs cost something like 50£ here so i think i will choose them if that conversion is that expensive choice, i do not have knowledge to sort myself those caliber spacers and washers. And for my brake problems i have reconditioned front calibers last winter and completely new rear brakes.
Cossie brakes are pretty expensive too, because those arent direct fit.
Old May 27, 2009 | 08:12 PM
mark-rst's Avatar
mark-rst
I got 2wd discs and rst calipers, i got these brackets to fit the calipers over the the discs
http://www.randbmotorsport.co.uk/sho...p?ProductID=49
Old May 27, 2009 | 08:17 PM
Antti O's Avatar
Antti O
Thanks! That price would be ok. If i order these brackets, is this completely bolt on conversion. So i order these brackets, go and buy patten cossie 2wd front discs and install those?
Old May 27, 2009 | 08:21 PM
mark2's Avatar
mark2
hi
you can fit 4x4 calipers and 2wd discs they are a direct fit no mods needed i have seen them go on ebay for about £100/£130 + post
and beleave me the hi spec set up needs spacers and a bit of filling off the rst caliper
also with cozzie brakes its 2 bolts and hi spec 4 bolts plus drilling the hub out if your not to good with these things cozzie brakes is bolt and go hi spec aint
mark2
Old May 27, 2009 | 09:05 PM
mark-rst's Avatar
mark-rst
yeah i bought new groved 2wd discs and uprated rst pads when i did the change over.
it all bolted together fine
p.s. this all fits under my s2 wheels.
Old May 28, 2009 | 05:15 AM
Antti O's Avatar
Antti O
Ok i will order those and get pair of cosworth 2wd discs
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
adam151082
Aug 11, 2015 04:50 PM
Old ford
Jul 31, 2015 06:50 AM
