Bara box
Passionford Thread Killer
The box is same spec as that was run in the Reyland 3 door. Uprated gear kit, slightly shorter 5th,uprated v/c,new syncros,standard main shaft and standard cut 1st gear,will come with shift cradle fitted with R&B short shift. Only covered 400miles since rebuild, covered 0 miles since i bought it. £3200.
Need your own clutch arm as mine was convered for hydro.clutch system and im keeping it with my car.
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
