Whats needed to fit a 4x4 engine in a 2wd car?
2wd oil feed pipe and sump, 2wd engine mounts, and the wiring for the idle control valve needs swapped over.
Think thats about it.
The CTS on the 2wd head is in a different place, but most of it should fit without much hassle
DMC
DMC
you can fit a 2wd sump directly onto a 4x4-engine, but you need to grind some alloy away so that the oil-spray-bars dont rub againt the sump.
as above, 2wd enginemounts with brackets to the engine.
the iscv is the same, is the wires on the TPS that needs to be changed.
the coolantsensor for your intrument is at the same place as the coolantsensor for the ecu.
also the water-hoses arent the same, but change to 4x4-system, much better. need a new header tank for that.
wiring is also diffrent.
ive just fitted a 4x4 engine in my mk 2 escort and space was a problem so i needed ..........2wd water pump ,2wd thermostat housing and thermostat,2wd crank pulley ,2wd water pump pulley,2wd sump,2wd oil pump and pick up pipe.......... its not as easy as you think..oh and for those who disagree
alternator adjusting arm and mounting block, starter motor, etc etc probably more but i cant remember
rog
Sep 4, 2015 12:10 PM
lockie
Jul 31, 2015 10:03 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
