Breaking 4x4 saff fairly good spec H16KOS now with pics
Old May 24, 2009 | 05:07 PM
trevCOSS's Avatar
trevCOSS
Default Breaking 4x4 saff fairly good spec H16KOS now with pics
Well unfortunately due to circumstances beyond my control the saff has to go. I have listed items below and will be adding to this list as time moves on, I can take pictures of items but pretty much everything has a picture in the rebuild thread. Prices at this stage are non negotiable but if Items do not sell I will of course look at prices. If you are interested in an item please send me a PM and post on this thread, I will make sure that Items sell to the first person that sends a PM. If you need additional info on something please feel free to ask. I have done my best to describe conditions etc, many items are very low milage and as new condition. Payment can be made via paypal (add 4%) cash on collection, check or bank transfer.
Pics can be seen here https://passionford.com/forum/restor...4-05-09-a.html
Small turbo inlet port matched to gasket (see rebuild)
complete with throttle body manifold spacer,
assembled using cometic gaskets £300
Front 330 ap brakes very low miles
very little wear £800 Sold ital_cossie payment received
4x4 rear callipers in ull working condition and the handbrake is also spot on. £80
Compression struts £80
Adjustable track control arms £80
Adjustable excentric spherical roller bearing top mounts £80
aeromotive fuel pressure regulator £120 Sold Paul S1 RST awaiting payment
Turbocooler £60 Sold to AndyEscos awaiting payment
Breather tank complete with -12 and -8
aeroquip hoses, fittings included to mate
hoses to block, rocker cover and oil return £200 Sold ital_cossie payment received
2wd ehaust manifold £100
Stack Wide band lambda £150 Sold to jason3door awaiting payment
Stack fuel gauge £100
SPA digital speedo £100
spa gauges x 3 EGT, Boost, water temp,
oil temp, oil pressure, fuel pressure £400 Sold to Richie (B9KOS) awaiting payment
L8 ECU fitted with wasted spark driver
complete with motorsport developments chip
running closed loop suited to
harvy gibs 400 400 spec engine £400
Dashboard face lift and in excellent condition £50
Interior raven cloth, in good condition although drivers bolster material is not perfect. inc seats door cards and carpet £300
Front bumper needs paint, complete with fiberglass rouse splitter and aerocatches in the sides £75 sold to CozzyKing deposit received
Front bumper plain needs paint £50
Rear Bumper (cracked in one corner and ehaust hole has been cut about) £20
Bonnett inc vents £80
Boot Lid with spoiler £40
Side Skirts (modded with alloy angle section so that they do not droop, makes them a much better fit than std DOES NOT include and jacking point covers) £50
Electric sunroof motor trim and entire roof mechanism not perfect but not rotten and works 100% ok £60
Rocker cover drilled for wrc style cam trigger £80
Cam trigger including rocker cover holder and the sensor £50
Turbo Damper bailey £80
Front diff, complete with strengthening plate £80
Rear diff £150
Front prop, good u/j's £50
Rear prop £30
Gear box donut £50
Colins engine mounts, brackets, same as Vibratechinics £100
Engine cradel (freshly blasted ready for paint or powdercoat) £30 sold Paul s1 RST awaiting payment
Vernier pullys (steel) £80
Driving side gauge piller pod and passender side piller flocked in black £35
Rear drive shafts £100
Fuel rail (standard rail with -6 fittings braised on either end and fuel pressure take off fitting braised on top) £30
Rear strut brase polished alloy £35
Dump valve £25 Sold Paul RST S1 awaiting payment
Alternator drop bracket £25
Alternator £50
Engine wiring loom £100 Sold Paul RST S1 awaiting payment
Avo Coil over suspension quite old but does work £100 sold to CozzyKing deposit received
ABS pump £40
ABS sensors £20 each
Power steering pump £20
Coil pack £10 Sold Paul S1 RST awaiting payment
Rear lights (smoked 90 spec) including number plate pannel £20
Head lights £40
Indicators front clear £10
Grill (not perfect and has no mesh) £25
Heater fan £10
Heater matrix £25
Steering rack £50
Centre consol (not including gearlever surround) or lid £20
Electric window switches (perfect working order, symbols not worn off) £15
Rear beam and arms with standard radius arm bushes powdercoated black £60
909 Motorsport plug leads to suit coil pack conversion £60 Sold Paul S1 RST awaiting payment
Rear parcel shelf, complete with 6x9 speakers £30
Kenwood frontdoor speakers £10
Starter motor £20
6 padel AP friction plate and standard cover (was fine with 450 bhp) £50
Amal valve £10
Clutch cable (quite new) £10
Wiper motor £20
Quickshift gear lever £30 Sold Paul S1 RST awaiting payment
Chrome engine lifting eyes £10 Sold Paul S1 RST awaiting payment
abs ecu 4x4 £30
I have lots more parts to add mostly small bits, if you see anything on the rebuild thread thats not advertised it just means i have not had chance to price it yet, drop me a pm and ask and it will go to the top of the list of things to price.
Old May 24, 2009 | 05:16 PM
cozzy940's Avatar
cozzy940
pics of comps
Sonic Boom's Avatar
Sonic Boom
pm'd
Old May 24, 2009 | 05:24 PM
DAN400's Avatar
DAN400
pm,d
Old May 24, 2009 | 05:31 PM
KSA-Cossie's Avatar
KSA-Cossie
I'll have the rev counter m8.
Old May 24, 2009 | 05:42 PM
KSA-Cossie's Avatar
KSA-Cossie
Any pics of complete dash trev ? And do they just plug into the existing lom connectors ?
Old May 24, 2009 | 05:45 PM
Mark 3D's Avatar
Mark 3D
Moderator
lol thats exactly the PM i have just sent!!
Old May 24, 2009 | 05:52 PM
Mark 3D's Avatar
Mark 3D
Moderator
See page 7 of the resto thread!!
Old May 24, 2009 | 05:53 PM
KSA-Cossie's Avatar
KSA-Cossie
Just seen it but is it plug and play to the o/e loom ? ?
Old May 24, 2009 | 06:17 PM
trevCOSS's Avatar
trevCOSS
its not quite plug and play but I can cut the new multiplug of my loom so you would just have to join wire for wire if you see what i mean
Old May 24, 2009 | 06:27 PM
dangerbrian's Avatar
dangerbrian
has the secs monitor sold mate
Old May 24, 2009 | 06:38 PM
KSA-Cossie's Avatar
KSA-Cossie
Can you give me some diagrams if i buy trev ?
Old May 24, 2009 | 06:45 PM
tezmanian devil's Avatar
tezmanian devil
would you be willing to sell me the blue comp mo centre cap's atall?
Old May 24, 2009 | 06:51 PM
trevCOSS's Avatar
trevCOSS
yes
Old May 24, 2009 | 06:52 PM
trevCOSS's Avatar
trevCOSS
for sure diagrams and pics
trevCOSS's Avatar
trevCOSS
PM me an offer
Old May 24, 2009 | 06:55 PM
DAN400's Avatar
DAN400
monitor is mine
Old May 24, 2009 | 07:08 PM
fezzajsy's Avatar
fezzajsy
any pics of the c pillars mate
andy escos's Avatar
andy escos
ill have your turbo cooler
Old May 24, 2009 | 07:10 PM
trevCOSS's Avatar
trevCOSS
you can pay cash on collection
Old May 24, 2009 | 07:15 PM
KSA-Cossie's Avatar
KSA-Cossie
Only really want the rev counter but will see if anyone wants any of the other gauges.
Old May 24, 2009 | 07:24 PM
andy escos's Avatar
andy escos
how much 4 your iscv &oil temp oil press gauge trev
ps answer your phone
Old May 24, 2009 | 07:37 PM
trevCOSS's Avatar
trevCOSS
Phone answered
Old May 24, 2009 | 07:47 PM
trevCOSS's Avatar
trevCOSS
Ill have to get some
Old May 24, 2009 | 07:48 PM
Wull79's Avatar
Wull79
U have pm cheers
Old May 24, 2009 | 08:16 PM
STUCOS's Avatar
STUCOS
Will take solid beam bushes trev
cheeRS stu
Old May 24, 2009 | 08:17 PM
trevCOSS's Avatar
trevCOSS
cheeRS stu
There yours, pm me to arrange payment and postage etc
Old May 24, 2009 | 08:33 PM
Stakis's Avatar
Stakis
Hey, I was first on oil pump?
Old May 24, 2009 | 08:40 PM
cossiedave's Avatar
cossiedave
got there befor you m8 sorry
Old May 24, 2009 | 09:19 PM
ital_cossie's Avatar
ital_cossie
you have p.m.
Old May 24, 2009 | 09:44 PM
trevCOSS's Avatar
trevCOSS
Originally Posted by ital_cossie
you have p.m.
replied
Old May 25, 2009 | 07:44 AM
cossi mat's Avatar
cossi mat
already a cossie nutter
hiya can u please send me some pics of fuel tank please and fuel pump and front strut brace please is the radiator a alloy what core is it ?
Old May 25, 2009 | 07:56 AM
trevCOSS's Avatar
trevCOSS
more added to the list
Old May 25, 2009 | 07:57 AM
trevCOSS's Avatar
trevCOSS
pics are in the rebuild thread, the rad is plus 10mm on std i think and yes its alloy
Old May 25, 2009 | 08:16 AM
KSA-Cossie's Avatar
KSA-Cossie
Have you still got the c/f surround that the rev counter was housed in 1st trev ?
Old May 25, 2009 | 08:18 AM
KSA-Cossie's Avatar
KSA-Cossie
gearlever surround (NOT BROKEN) £30
If it's black and for the 4x4 i'll have it trev.
Old May 25, 2009 | 08:22 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
pm'd twice on oil cooler and other item. CheeRS
Old May 25, 2009 | 08:26 AM
trevCOSS's Avatar
trevCOSS
dont think so
Old May 25, 2009 | 08:27 AM
trevCOSS's Avatar
trevCOSS
it is and it is, i'll stick your name down, please pm to arrange payment etc.
Old May 25, 2009 | 08:36 AM
KSA-Cossie's Avatar
KSA-Cossie
pm sent m8.
