engine doesn't start
Old May 23, 2009 | 09:24 AM
Boreham Works's Avatar
Boreham Works
Default engine doesn't start
Hi,
I own "ESCORT RS COSWORTH / T25 Small Turbo" in Japan.
It encountered the trouble that the engine doesn't start.
First of all, I doubted the fuel pump.
I connected the power supply directly with the connector of the fuel pump.
Fuel pump operated unlike my expectation.
However, the engine doesn't start.
Please advise if there is a cause of it.
Thanks, Jick
Old Jun 13, 2009 | 06:46 AM
Boreham Works
Hi,
I tried the self-diagnosis function.
But, I do not understand fault-codes.
I took a video and up-loaded it.
http://www.youtube.com/watch?v=13tV-YCJbnU
Will anyone give me advice?
Thanks, Jick
Old Jun 13, 2009 | 08:10 AM
- Sim -'s Avatar
- Sim -
looks to me like 3 blinks, so Code 3, but I don t know what this is.
is there a spark? Did you put the plug wires out and turn key? to see if there is a ignition spark? There is fuel at the rail and injectors?
Old Jun 13, 2009 | 09:38 AM
Are the injectors firing, is there a spark.
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
Zoggon
Aug 10, 2015 10:39 AM
slammedorion
21
Aug 6, 2015 11:38 AM
Old ford
Jul 31, 2015 06:50 AM
