hi, anyone know if the 4x4 throttle bodys a better one to use than a 2wd one.. eg. would it make any difference ? i am using the 4x4 inlet with the 14mm spacer, but still using the 2wd throttle body with the red tps? any idea folks ?
thanks
No difference in body 2wd to 4x4 only the idle screw 4x4's can seize
4x4 plenum is a little bigger and elbow a better design
small turbo escos plenum is excellent but requires a few mods for sensor and you can't use a small turbo t/body due to iscv are different shame cos the throttle body itself is bigger
