Big Turbo Cosworth Escort weak spark
Old May 22, 2009 | 06:30 PM
cossieford's Avatar
cossieford
Default Big Turbo Cosworth Escort weak spark
Car has 4000km. Cannot get enough of a spark to start. The ground is good. Changed coils twice. Changed ignition module. Changed crank sensor. Distributor and leads are new. Volts at coil are good. Timing checked. Anyone have any ideas??
Old May 23, 2009 | 05:26 PM
grcossie's Avatar
grcossie
Are you sure it dosen`t got to much fuel ?
Old May 28, 2009 | 08:59 PM
westus1's Avatar
westus1
nothing realy left to try, if new dist has new phase sensor, then i'd agree that maybe there is another problem?
Old May 29, 2009 | 04:46 AM
stevecossy's Avatar
stevecossy
I guess you have changed the plugs? Maybe try a group A coil and check fueling as gr cossie says.
Try some "start ya bastard" easy start spray.
Old May 29, 2009 | 06:22 AM
costina's Avatar
costina
Live long and prosper!!
wiring multi plugs cut out and solder
Old Jun 18, 2009 | 10:05 AM
Stu @ M Developments's Avatar
PassionFords Creator
Agreed. This is likely your problem.
Aug 14, 2015 07:29 AM
Blown Hell
Aug 5, 2015 07:22 AM
adriansaleem
Aug 1, 2015 09:28 PM
ginger1979
Jul 31, 2015 09:56 PM
Escortdriver1
Jul 31, 2015 02:36 PM
