Bilstein 909 Rear Top Mounts
ronnie, you can space them out from the shell with offset bearing spacers, to stop the annoying catching on the inner arch.
also same as anything with rose jointing over bushing, just aids a more precision and accurate supension.
Yes, but what i mean is how do you fit the spring cups to them? Do you have to pry them apart? I unscrewed the spring seat off the bottom of mine to change the springs.
Perhaps he also means Are you supplying the rest of the kit , the spring Top cap you described as the top hat , the circlip that locates the top cap etc.. Or just the top mount that takes the spherical bearing
jessie_rs
11
Jun 3, 2019 04:57 PM
Oct 9, 2015 07:38 PM
xr4x4rs
Aug 6, 2015 09:03 PM
