modified mk6 escort breaking
as above, breaking my mk6.
prices do not include postage.
smooth bootlid - £30
needs a tad more smoothing, window needs a new rubber
morette headlights - £120
one of the outer lens's is slightly rusted inside and only one inner (other used as cold air fed) [/b]
Pumaspeed 300mm front brakes - £100 (prov sold)
inc disks and calipers, still in good condition.
disked rear beam (polybushed) - £175
IIRC i put new pads in just before i took the car off the road.
gearbox from a 1.6 cvh escort - £30
front starter, needed to fit a cvh turbo engine to a mk5/6.
sierra cossie vented bonnet - £40
underside needs tidied up, but in good condition.
mk6 rs2k interior - £120
small tear on drivers bolster as usual, incs matching doorcards for a 5 door.
mk2 mondeo centre console - £15
was gonna modify it to fit into the escort but never got round to it.
flocked dash fascia and gear stick surround - £40 (prov sold)
flocked black, never been fitted to a car.
digital dials (from a fiesta) - £30
bought to fit to the escort, plenty of guides about on how to do it, has the plug for the back of it too.
sender unit for digital dials - £25
needed to get the correct readings from the above, straight fit - no fuel pump.
16" azev A's - £300
in good condition, with centre caps, 4 good kumho tyres.
16" azev a replicas - £120
almost identical to the above wheels except with a very slight dish, good tyres and multidit (unsure of other size, 4x100?)
5 spoke 15 alloys - £30
just basic 5 spoke alloys needing 2 tyres
mk5 front strut brace - £25
mk6 front strut brace - £40
AVO adjustable coilovers - £150
in decent condition, springs look a little rusty due to sitting about for a while but will clean up with a wire brush.
FRST gearbox and shafts - £40
2l conversion kit - £70
everything you need from the 1.8 to covert your 2l to run in an escort - water pump, oil pick up and sump, flywheel, inlet, exhaust manifold.
im sure theres millions of other bits that ive not listed, so ask if your after anything, may also take an offer on the shell if anyones interested - see my project thread for pics.
16" azev A's - £300
23
Sep 12, 2015 12:56 PM
