Anyone got pics of their boot brace? Need some insparation/ideas, thinking of getting either coilovers or fully adjustable shocks all round and need to reinforce the turrets. what have you got and where from or how you made it?
Cheers! The plan is to fit a cage in the near future yes when funds allow, i wanted peace of mind whe fitting the coilovers so thought this would be a good start and form the basis for a cage at a later date
Wow! did you do that yourself? how are the turrets done? looks very strong mate
I'm afraid i can't take the credit for doing those mate lol! The original turrets were cut out right down into the wheel arch then the new turrets measured/fabricated and welded into place, with the bracing to strengthen/stffen it further. I paid a lot of money originally to have them done but the company measured things wrong and they ended up sitting too high meaning the coilovers didn't fit correctly. Unfortunately they shifted the blame and insisted the coilovers were definately wrong, which they were to an extent but as they were refabricating the turrets they could have remedied the problem by adjusting the height of the turrets to suit. To cut a long story short i ended up having an engineer friend of mine chop the tops off to make them lower and redo the bracing to a much higher standard!
