S2 master cylinder with ABS 25mm bore
i need help asap
i have a s2 rst and the master cylinder has gone, it is impossible to find a decent one about as it is the ABs one with the 25mm bore and 2 outlets.
does anyone know if there is one off another car that will work?
ive heard you can use one from a galaxy (1995 on), land rover, Ford Puma (97 on) or orien.
can anyone clear this up for me, cheers, tim
