At what point is a single 044 pump not enough???
Old May 13, 2009 | 02:00 PM
focus 4x4's Avatar
focus 4x4
Default At what point is a single 044 pump not enough???
So at what point do you decide that running one pump is not enough for the power/spec of your engine? whats the advantage of running two 044 pumps? or is it just simply a reliability thing?
Old May 13, 2009 | 02:07 PM
focus 4x4's Avatar
focus 4x4
Old May 13, 2009 | 04:39 PM
costina's Avatar
costina
Live long and prosper!!
if one fails that would be the only reason i think there good for 600 bhp with ease
Paul
Old May 13, 2009 | 04:56 PM
focus 4x4's Avatar
focus 4x4
Paul
Thanks Paul, you say one pump alone is good for 600bhp....?????
Old May 13, 2009 | 05:19 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
I have a single 044 on my new Evo at 575 bhp.
Not sure what the upper limit is yet. Wiring needs to be spot on as you want max volts at the pump to get the most out of it.
Big difference between 12v and 14.4v
Si
Old May 13, 2009 | 05:50 PM
focus 4x4's Avatar
focus 4x4
Paul
Old May 13, 2009 | 05:53 PM
focus 4x4's Avatar
focus 4x4
Thanks Si ill be more than happy to get 500 hp from my cosworth engine in its current spec. so one 044 pump should be more than up for the job ( with a new fuel pump loom of course)
Old May 13, 2009 | 08:05 PM
costina's Avatar
costina
no worries ust know a fella who had over 600 bhp with no issues as i can remember a 044 pump produces 10 bar so plenty imo
Paul
Old May 13, 2009 | 09:12 PM
J1mbo's Avatar
J1mbo
B1mbo
what fuel pressure is this 600hp 044 ?
Old May 13, 2009 | 09:34 PM
Jim Galbally's Avatar
Jim Galbally
i didnt think fuel pressure was relevant with pumps? only flow rate?
Old May 13, 2009 | 10:00 PM
J1mbo's Avatar
J1mbo
B1mbo
with a 044
on a yb, with 52psi fuel pressure the limit (i thought) was about 500hp
i didnt know wether upping the pressure/making the 044 work even harder if it can possibly work harder ?? would allow it to flow enough fuel for more power
tbh im not sure on this so i ask questions lol
Old May 13, 2009 | 11:28 PM
zetecturbo's Avatar
zetecturbo
ha.never mind the questions ,where did you get the fuel pump holders.
Old May 14, 2009 | 08:16 AM
daviddunlop83's Avatar
daviddunlop83
The fuel pump brackets looks really well. Who does them or was it a one off?
Old May 14, 2009 | 08:24 AM
lead_foot's Avatar
lead_foot
is awesome
Originally Posted by J1mbo
with a 044
I thought the limit was 5 bar (72psi).
Old May 14, 2009 | 11:05 AM
costina's Avatar
costina
044 flows 4.4 litres per min @3bar
Jimbo what do you use on the dyno?
Paul
Old May 14, 2009 | 11:48 AM
foreigneRS's Avatar
foreigneRS
Testing the future
they are interlinked. as pressure rises, the capacity to flow reduces.
Old May 14, 2009 | 11:50 AM
RAT8OY's Avatar
RAT8OY
At last!
Somebody talking sense!
Old May 14, 2009 | 11:57 AM
alanfordtw-15's Avatar
alanfordtw-15
if the pressure on your gauge starts to drop then flow will also drop, if it can never build up the pressure it def wont be able to flow enough..
Old May 14, 2009 | 12:04 PM
GARETH T's Avatar
GARETH T
not strickly true,,, the pipe might of come off your fuel rail,,,pressure has dropped but flow has massively increased,,,,,all over the road PMSL
Old May 14, 2009 | 12:34 PM
Stu @ M Developments's Avatar
PassionFords Creator
Correct.
Interesting reading for some....
http://www.motorsport-developments.c...AF242_tech.jpg
Old May 14, 2009 | 01:23 PM
costina's Avatar
costina
you really need to ask yourself what pressure you running at(fuel rail) and what boost you are going to have which will increase rail pressure too
Maybe i could have given incorrect info saying 600bhp but this guy was'nt running big boost
seen a few 500bhp engines with ony the 1 pump so with 2 your going to be really safe
Text my mate and he only had 1 pump and ran 30 psi of boost
Paul
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
