how to remove 3 door front bumper?
There is a plastic clip you twist on either side and pull out inside the wheel arch. Then you have to remove the grill and you will see two bolts onto the chassis leg you need to remove them it will pull off.
jessie_rs
11
Jun 3, 2019 04:57 PM
rog
Sep 4, 2015 12:10 PM
