leaving ECU unplugged.
Carbon Crazy
With my ECU quite accessable in my car, ive been thinking of just removing the ECU each night/when im at work as thats a pretty damn good detterant to them trying to start it!!!!
on P8 what will you loose by disconnecting it from a power source??? Nothing important i hope!!
That shouldnt be a problem at all I would imagine, but check with your mapper is the best answer, I cant imagine them having anything on there that in anyway cares if it loses power for a while or not though.
Removing it is not a problem at all.
Nothing is saved in memory that needs a permanent power supply.
If you look at a wiring diagram you will see there is no permanent power supply.
All power to the ecu is switched off when you switch off the ignition.
So, removing the ecu entirely does not change anything, as long as it is a Weber-marelli.
Carbon Crazy
1 point to note is that an ECU and its pins and the connector are designed to be permantently connected.
If you start unplugging and replugging twice a day then you could soon run into reliability issues! It might not be just the thief who can't drive your car away!
Paul
Paul
just fit a quick release steering wheel and a gear box lock i have one to fit in mine multilock its called ! i had one in my ecos since it lived on the road and never worried about it going walkes! i will take a pic and send it they are good
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
