Various silicone pipes and alloy pipes (some samco)
1 - 40mm Internal Diameter x 915mm long, black, this one is reinforced rubber
2 - 70mm ID x 45mm ford pipe
3 - 50mm ID x 210mm (outside length) 90 degree bend
4 - 50mm ID x 75mm
5 - 70mm ID reducer to 60mm ID x 125mm
6 - 60mm ID reducer to 50mm ID x 105mm
7 - 65mm ID x 75mm Unknown make, doesnt say samco
8 - 50mm ID x 110mm Unknown make, doesnt say samco
9 - 65mm ID x 65mm Black, Unknown make, doesnt say samco
10 - 30mm ID x 280mm with 10mm bleed nipple
11 - 5mm ID x 1590mm Vac pipe, unknown make, doesnt say samco
12 - 60mm ID (64mm Outside Diameter) x 280mm (long egde) 90 degree bend, alloy
13 - 60mm OD x 40mm polished alloy
Looking for £60 delivered for the whole lot, or will sell each pipe individually for £7 delivered.
Dez
4 - 50mm ID x 75mm
Dez
