RR day at Torque of the devil
Old May 10, 2009 | 10:09 AM
Icurus's Avatar
Icurus
Default RR day at Torque of the devil
Our club had a small gathering at TOTD yesterday to blow out the cobwebs on our cars after the winter layup.
Just thought i'd share my results, which I know are not jaw dropping when compared to anything with a turbo and would not excite most people on here but they made me happy
Not done much to the engine since I was last on the rollers at Power Engineering, but It made more torque and less HP this time
186.2 FWBHP - 212lbs/ft on gas
and
156.8FWBHP - 149lbs/ft off gas
Heres the printout
and here's a vid of the first attempt on N2O that they stopped as the car tried to leave the rollers, and they had to add some more straps
Old May 10, 2009 | 02:29 PM
AlexF's Avatar
AlexF
Still playing with RS2ks huh
Old May 10, 2009 | 03:19 PM
fezzajsy's Avatar
fezzajsy
nice
Old May 10, 2009 | 08:06 PM
Icurus's Avatar
Icurus
Hi Alex!
Yeah, but im down to my last one
Old May 10, 2009 | 08:53 PM
AlexF's Avatar
AlexF
Nearly kicked the addiction
Old May 10, 2009 | 09:39 PM
GavStyli's Avatar
GavStyli
Kasapis
nice one mate, what system you running and what size jets?
does the gas cut off before engine hits the limiter?
Old May 10, 2009 | 10:04 PM
Icurus's Avatar
Icurus
I think i'll be keeping this car for a while Alex, hell, it owes me soo much i'll never break even selling her
GavStyli, its a WON system with approx jetting for 50bhp, tho it made just 30bhp on the rollers but I think the bottle was nearly empty as I had a bit of a play on the way to TOTD
Its triggered by a WOT micro switch, soon to be a TPS switch, so keeps firing even when the limiter hits which cuts the sparks so I dont think it will damage the engine, but it will waste gas until I snatch the next gear, if there is one available
Ultimately I would like to get a digital progressive controller from WON and take proper control of the whole system
Old May 10, 2009 | 10:31 PM
GavStyli's Avatar
GavStyli
Kasapis
look into the max extreme controller by won, im running the street version, pukka peice of kit mate!
Old May 10, 2009 | 10:53 PM
JonnyBravo's Avatar
JonnyBravo
Good results that !
Does the car run a air flow meter ? if so hitting the limiter can cause the hot wires in there to be damaged or even a inlet backfire so I wouldn't advise it if you can avoid it.
Old May 11, 2009 | 04:16 PM
Icurus's Avatar
Icurus
No air flow meter JB, just a MAP senser
Good to know about the air flow senser trouble though in case someone I know has probs!
The Maxextreme is top of my list, just got to convince the Mrs its a must have item
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
DavidK
Sep 27, 2015 02:55 PM
