Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
ford escort mk6 p-reg rev counter wiring
Old May 9, 2009 | 03:13 AM
georgep609's Avatar
georgep609
Default ford escort mk6 p-reg rev counter wiring
i have a p-registered 1.4 escort encore. i took the white clocks from an escort si yet cannot get the rev counter to work. i beleive it takes the signal from the ecu, does anybody know which pin on the ecu the signal comes from? any help would be much appreciated
Old Nov 29, 2010 | 07:54 PM
Smithdog's Avatar
Smithdog
Hi there, i know its been a while but did you ever get ur rev counter working? i have same problem with s reg si mk 6 but not received any help.
Have read on forum blue socket number 8 to number 4 or summin not sure, what do you reckon????????????
cheers.
Old Nov 30, 2010 | 02:27 AM
georgep609's Avatar
georgep609
hi there, i got rid of my car before i did the job but i was informed by various people that it was pin 8 on the blue plug and 4 on the ecu. if you do it would you let me know if it works as i have an escort cl estate in my garage with gti clocks and dead rev counter so am planning to do the job myself sometime soon.
Old Nov 30, 2010 | 08:57 AM
Smithdog's Avatar
Smithdog
Nice one, thanks for the reply, hope to spend some time today in the dashboard due to the snow stopping me working.
Old Nov 30, 2010 | 12:28 PM
Smithdog's Avatar
Smithdog
WAHAAAAY. Just got out from behind the steering wheel (3 hours). white dials and new white clock fitted and believe it or not the rev counter WORKS ! no extra wires at all. Must have loomed in all necessary wiring to late mk 6 models for the sake of it.
good luck with your estate. Paul.
Old Nov 30, 2010 | 12:53 PM
georgep609's Avatar
georgep609
my clocks are already in my esate but the rev counter is dead . i think i am going to invest in a new set of clocks and try that before i mess with the wiring. good result for you tho mate saved you a lot of messing
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
