monte carlo rs cosworth help needed
Old May 8, 2009 | 09:36 PM
montecarlo163's Avatar
montecarlo163
Default monte carlo rs cosworth help needed
Hi all i own a escort cosworth jewel violet monte standard with low miles
just 2 probs and help needed ,when it runs the idles rough ,also misses a beat now and again while driving and the fuel warning light keeps flashing and also the fuel guage reading keeps going up and downneed expert help here peeps as would like to sort her myself
Old May 8, 2009 | 09:53 PM
paul16v's Avatar
paul16v
Monte 087
Ive got a j/v monte aswell
Fuel guage sounds like the sender in the tank could be fubard. Not quite sure on your other problem could be any number of things there is alot of people more technically minded on here that will be able to offer advice
Old May 9, 2009 | 12:39 PM
JHS's Avatar
JHS
Try www.escortrscosworth.com
Old May 9, 2009 | 06:59 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Im no help, but i had a J/V Monte no183.
Old Aug 24, 2009 | 10:46 PM
cossimc's Avatar
cossimc
sounds to me like a idle speed controll valve take it out and give it a good clean with carb cleaner this will might help in investigating the problem without a costly guess
the fuel problem cud be a faulty sender unit check that ur getting a constant feed to the sender and not intermitent . check the multiplug for corroding
Old Aug 24, 2009 | 10:55 PM
Kelv's Avatar
Kelv
Almost there!
Originally Posted by JHS
what he said
Old Sep 12, 2009 | 07:16 AM
AJC's Avatar
AJC
as above
carlo
24
Oct 5, 2015 08:20 PM
Aug 14, 2015 07:29 AM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
