wanted!
3 bar map sensor,greens,chip for l6 to run them.
breather kit.
boost gauge
oil pressure gauge
water temp gauge
2wd speedo cable
handbrake set up to fit mk3 escort or something that i could modify to run 2wd cossie rear calipers on a mk3 escort.
steering wheel-suede or rs 4 spoke etc to fit mk3 escort.
all as cheap as poss as im poor!
breather kit.
boost gauge
oil pressure gauge
water temp gauge
2wd speedo cable
breather kit.
boost gauge
oil pressure gauge
water temp gauge
2wd speedo cable
breather kit.
boost gauge
oil pressure gauge
water temp gauge
2wd speedo cable
steerfromdarear
28
Jan 29, 2016 06:14 PM
Ben26
Aug 27, 2015 08:56 PM
