removing front d/s driveshaft
my driversside drive shaft decided to disintigrate on me earlier, having trouble getting it out, the cv joint cup doesnt seem to want to come out of the box, n e tips?
There is a clip holding it in you have to take the plate off the bottom of your front diff to get to it. Its worth checking your engine mounts while you are on as the drivers side mount is notorious for breaking leading to the front drivers shafts pulling out.
i was having the same problem with the d-s drive shaft
now i can sort it i also bought vibratechnics engine mount was told aswell they are far better worth the money
cheeRS guys
cheeRS guys
matman
Sep 9, 2015 05:45 PM
track.focus'd
Aug 12, 2015 05:53 PM
