xr3i revs out at 5500rpm, normal???
hi. my 1989 xr3i tops out at 5500 rpm, is this normal? iv read that the max bhp is at 6000rpm yet mine does not reach this, and the red line on the dials is 6500rpm. it doesnt top out as such it just seems like the fuel cuts completly, could it have a rev limiter? and if so how do remove it? cheers.
was it only certain ones that had this? my xr3i cab doesnt and revs bang up to 6300 near enough ive found out once, never dipped the clutch in so much when i remembered theyre not meant to go above 6000!
It works centrifugally so as the revs rise a plunger comes out and touches a plate at the side of the arm and shorting out the spark going to the plugs hence limiting the revs try a differant arm but not from halfords as i bought one for my old car from there that had 6500 on the side but like yours wouldnt rev over 5k got one from a motor factors back up to 6 1/2k revs.
mark.
mark.
I modified my old mk3 3i's rotor arm (many moons ago)...that night afterwards, I was replacing the exhaust valve that it dropped
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
