cosworth tapping after rebuild..has now cut out and no spark. :(
Old May 7, 2009 | 07:57 PM
neilsrsturbo's Avatar
neilsrsturbo
cossie
Angry cosworth tapping after rebuild..has now cut out and no spark. :(
I managed to get the car started..... once the car started it made a really loud tapping noise, but after about 30miles it died down. when the car is on idel there is a faint tapping noise, but as soon as i accellerate off the mark and through the gears it gets louder and quicker. when the car is at 65mph the sound seems to get quieter again???? the car is running really smooth and isn't miss fireing or smoking. If thats not enough driving home from work today it just cuts out......now no spark ahhhhh!!! help me please i've been doing this rebuild for a year now and want her finished..lol.
Old May 7, 2009 | 08:16 PM
Eagle's Avatar
Eagle
Super Moderator
would ask the obvious about timing ... only needs to be a bit out on the belt ...
Old May 7, 2009 | 08:28 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Did you aling the bottom pulley with the right marking.
Steve
Old May 7, 2009 | 08:31 PM
col cos1's Avatar
col cos1
dont know about your misfire mate,but dont worry about the lifters they will quieten down with miles mine came and went and took ages
Old May 7, 2009 | 10:05 PM
neilsrsturbo
cossie
i have no miss fire on the car, just a tapping noise. yeah timed the car up exact on the lobe. before timing i downloaded the cosworth workshop manual. i timed it up on the lobe thing not the groves.
Old May 7, 2009 | 10:16 PM
col cos1's Avatar
col cos1
just get the miles on it,it will be fine
Old May 7, 2009 | 10:25 PM
cozmeister's Avatar
cozmeister
More boost Igor!
So presumably with No 1 at TDC, both the arrows on the cam pulleys point right at each other?
Did you replace the tappets? They will make a proper racket when they're new - get an oil and filter change done. If it's coming and going it's most likely the tappets. Mine does it - silent on startup, then gets a little tappety, then goes quiet again. Do you have an oil pressure gauge?
Old May 7, 2009 | 10:26 PM
babscossie's Avatar
babscossie
Is it louder when you put more load on the engine??
Old May 8, 2009 | 04:44 PM
neilsrsturbo
cossie
going to put a oil presseur gauge in the car. yeah the sound gets louder under load?
Old May 8, 2009 | 09:08 PM
LHD220Turbo's Avatar
LHD220Turbo
the tappy noise; is it top end or bottom
Old May 8, 2009 | 11:26 PM
philram's Avatar
philram
Mulechild
its not the lugs on your bottom pulley hitting the crank sensor is it..?
edit.. just realised you've probably got an rst, i'm thinking cossie, so dont know if its a possible or not.
Old May 8, 2009 | 11:30 PM
Moonstone Steve.
Its a cossie m8.
Steve
Old May 8, 2009 | 11:36 PM
philram's Avatar
philram
Mulechild
Originally Posted by Moonstone Steve
Its a cossie m8.
Steve
so it is, just reread it..
i refer the gentleman to my first answer then..(done that one myself)
Old May 9, 2009 | 03:11 PM
babscossie's Avatar
babscossie
if the tapping noise sounds loud and deep/knocking, sounds like a big end.
was the crank checked/ground when engine was rebuilt??
correct undersized bearings used??
Old May 10, 2009 | 03:55 PM
neilsrsturbo
cossie
it was the tappets the noise has now gone. as for the car cutting out it was a fuse for the fuel pump. all is sorted and she is running like a dream, all ready for the shows.
Old May 10, 2009 | 03:57 PM
LHD220Turbo
glad to hear it
Old May 10, 2009 | 07:37 PM
Moonstone Steve.
Good news m8, look forward to seeing it again
Steve
Old May 10, 2009 | 07:53 PM
Alvyn's Avatar
Alvyn
tappets CAN take a good few miles to fill completely after a rebuild! ALLS good then!now just get some miles on the clock!
3dr cossie
11
Dec 21, 2015 03:38 PM
jay030787
Sep 18, 2015 07:34 PM
lukeeboy149
Aug 22, 2015 04:29 PM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
