ABS problem
Old May 7, 2009 | 12:25 PM
ybturbo's Avatar
ybturbo
Default ABS problem
Today after a short road stop my abs light together with handbrake light stayed on with pump buzzing. The ABS is not working (the wheels are locking). Both lights stays on just the moment you turn the ignition on and also the pump buzzing all the time. The pedal became softer too but still good brakes. Possible causes?
Old May 7, 2009 | 12:27 PM
ybturbo's Avatar
ybturbo
Forget to say that brake fluid level is higher than before when car working.
Old May 7, 2009 | 05:05 PM
ybturbo's Avatar
ybturbo
Well it is weird but problem dissaperared. Now working correct... Still what is the cause for that issue? What should I check?
Old May 8, 2009 | 05:22 AM
ybturbo's Avatar
ybturbo
Oh come on nobody knows something about this?
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
