Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Does the rs2000 4x4 have the same rear axle mounting points as the fwd version ?
Old May 3, 2009 | 07:52 PM
Kverna's Avatar
Kverna
Virgin-popper
Default Does the rs2000 4x4 have the same rear axle mounting points as the fwd version ?
Anyone cross fitted them ?
Old May 3, 2009 | 09:07 PM
Icurus's Avatar
Icurus
It use's some of the 2wd's rear beams mounting points, but then you also will have to drill some more as the 4wd's cradle has 4 mounting points and the 2wd's beam only has 2, but it will fit as I plan to do this to my track car to allow adjustability and I think its also a lighter setup too.
Old May 4, 2009 | 04:47 AM
Kverna's Avatar
Kverna
Virgin-popper
Cheers mate
Oct 9, 2015 07:38 PM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
xr4x4rs
Aug 6, 2015 09:03 PM
Old ford
Jul 31, 2015 06:50 AM
