driveshaft wont come out.
Old May 2, 2009 | 08:05 PM
orionmojo's Avatar
orionmojo
Default driveshaft wont come out.
dogged my box out today and i cant get the offside driveshaft out. i used all my levers and crobars but nowt. i even tried a brass knock stick through the box and hammered the shit out of it, but it hasn't even moved a mm. the box is out on the floor now, but i still cant get the shaft out so i can send the box away.
does anyone have any ideas? i'm thinking next thing is to tie one to a lampost and the other to my pickup tow hitch, then just drive off
Old May 2, 2009 | 11:00 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
get a pair of long nose pliers and semi wedge them in the gap,hit them with a hammer, if not a flat screw driver or a solid shaft thru the other shafts hole and bash it out this way
Old May 3, 2009 | 08:54 AM
studabear's Avatar
studabear
2 levers at once so you are putting equal pressure against 2 sides
Old May 3, 2009 | 08:59 AM
cabriolet's Avatar
cabriolet
ford had a big fork for releasing them equal pressure on each side is the way to go as said already
Old May 3, 2009 | 09:55 AM
orionmojo's Avatar
orionmojo
ok cool i'll try the two levers.
i was really stuck after it wouldn't come out even after i'd bashed it with a bar straight through from the other side.
mondeomark
Sep 28, 2015 06:28 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
pabloXR
Sep 21, 2015 12:42 PM
Brickhouse
Sep 21, 2015 11:00 AM
rsturbo27
Sep 5, 2015 05:08 PM
