what size valves
Old May 2, 2009 | 06:55 PM
jp indy3's Avatar
jp indy3
Default what size valves
im building a pinto turbo,dose anyone know what size valves would be best?
Old May 2, 2009 | 08:14 PM
It's not as important as na obviously as it's forced induction, unless you want mega silly power std should be fine.
I would phone HT racing as they are wizzards with pinto's.
Old May 3, 2009 | 08:56 AM
jp indy3's Avatar
jp indy3
i did think that was the case,i have one of vulcans maxiflow1 heads 45.5in 36.5ex,would this be ok to us as it is unleaded,if not i have a std head???
Old May 3, 2009 | 08:59 AM
jp indy3's Avatar
jp indy3
Default valves
hi there,i have one of vulcans maxiflow1 heads 45.5in 36.5ex would this be ok to use?????
Old May 3, 2009 | 04:04 PM
You could use this but I would check with vulcan on the exhaust valves, normally these are sodium filled on t/charged due to immense heat, that would be my concern.
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
