200 block big turbo / small turbo question
Hello all
i ve a question
the 200 blocks used at small turbo engines and big turbo engines are slightly different.
but does the big turbo 200 block also have oil spray jets?
can the ones from the small turbo be adopted in case of just changing them without machine work?
or does the big turbo block have to be machined?
Please let me know if you have ideas.
thanks
i ve a question
thanks
All Cosworth engines have oil jets, 200 block, have a oil pipe from oilpump house, whit jets.
Her is how you can modyfi to have jets like small turbo engine. Sorry for norwegian
http://www.fmcn.no/forum/index.php?showtopic=45892
ok thanks a lot.
the problem is my small turbo block is already on 2nd bore and for new pistons 3rd bore will have to be made, and don t think that is too good for power issues....
so i got a 200 block from a big turbo modell, which I want to put my small turbo head on, but get the nice spray jets from small turbo block
Anyone has the finis codes from the small turbo jets? or knows where to buy?
ok thanks a lot.
pistons are 91.00 mm, block is therefore frehsly bored and honed, standard rods, standard balanced crank
will put my small turbo head on with changed cams and GT30 Turbo, looking for not more than 450 hp
i m wanting an internally gated GT3076, can post the link later on, same was developed for M.A Developments....
double valve springs - check
6 long studs - can be done as soon as the block arrives, some headwork has already been done, new valves as well as bronze guides are here...
are JE Pistons that good? I heard of many fails. Accralite may be an alternative for you?
Pickup pipe is not the same, as on big turbo, the oil jets sits on a pipe welded to pickup, and it`s not the same oilpump.
I allready have je piston, it`s many big power cossies her whit them, don`t think thats a problem
ok good info
but can the small turbo pipe be used, does it fit the big turbo pump?
as I want to get the big turbo block machined to get used of piston spray jets.
could you let me know which car the jets in the picture are from, and in one pic it looks as if they are modified by 90 degrees, is that correct
thanks
PAUL
If you use Zetec ones, the best is to heat them before bending
I'm also in the works to modify a 200 YBT block to take in those BMW Z3 spray jets.
Here are a few images of the jets:
http://farm4.static.flickr.com/3378/...3ed8c91c_o.jpg
http://farm4.static.flickr.com/3590/...40632c7f_o.jpg
http://farm4.static.flickr.com/3356/...1ee4b31c_o.jpg
Does anyone have more images of the modified blocks, as I don't have mine yet modded and would like to have some reference images.
where the jet sits there must be a plan or even area, it can be done with a simple driller or so.
get a machine shop to do this, as any faults may be very very expensive....
The link i gave up her, is from an great engine builder who makes many things himself, like adjustable vernies, dobbel valve springs ect. He is a man ho show how things can be done cheap and do it yourself thing
Got mine done already, so just thought I'd share the info.
Block was machined like this:
http://www.flickr.com/photos/anttit/...7601253829082/
Pistons were free hand machined a bit to accept the Z3 jets:
Peekaboo:
The whole lot, nice and tidy:
Peekaboo:
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
