mondeo tdci
hi i have a 2002 mondeo zetec s tdci and when accelorateing above 3000 revs in 2nd or 3rd gear the car goes into safety mode and the glow plug light flashes and there is a rattle just before the light come on?
Been on diagnostics twice came up with the same sensor so changed that [fuel pressure sensor] that did not work and i have triedmy old sensor on a friends car and it worked fine.
I have had a few of these doing exactly the same issue , ok until it comes onto boost and pulling hard , the trouble is the fuel pressure sensor code is a bit of a red herring , the problem can be the fuel pressure control valve , it is being told to move and it is telling the PCm that it has moved but it is not controlling the fuel pressure correctly , sometimes due to swarf within the system . the best way is get a data logger test done see what the required pressure is and the actuall pressure , if they do not match chances are it is a IMV ( inlet metering valve ) that is sticking , it is getting the signal to move , it sends back the signal that it has moved but it has not altered , the bad news is that depending on what pump you have depends if you need just the IMV or a complete pump .
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
The Enigma
Sep 29, 2015 10:31 AM
