failed test..
Old Apr 30, 2009 | 04:32 PM
an1mal_69's Avatar
an1mal_69
Default failed test..
failed MOT today..pretty catastrophic rot on the rear chassis leg (not what you expect after blowin nr £5k on a motor but thats a different story).
If i hadnt have know the tester he said he would of condemned the car whats the best way to attack this..?? Are chassis legs available or is it gonna be a plate job d'ya rekon..??
Old Apr 30, 2009 | 05:09 PM
Barry R's Avatar
Barry R
Bad news mate but what car is it
Old Apr 30, 2009 | 05:10 PM
andy130's Avatar
andy130
find another car the same cut the part u need out make sure its larger then cut yours out and trim it down to the size u need it to be and weld it in happy days
Old Apr 30, 2009 | 05:11 PM
Barry R's Avatar
Barry R
Is it a 4x4 cossie
Old Apr 30, 2009 | 05:12 PM
Barry R's Avatar
Barry R
I am cutting a 3 door shell up mate if they are the same
Old Apr 30, 2009 | 05:25 PM
iansoutham's Avatar
iansoutham
OCD Victim
Speak to Charlie Luciano on here. He has a spare brand new rear chassis leg for sale
Old Apr 30, 2009 | 05:38 PM
LHD220Turbo's Avatar
LHD220Turbo
find a breakers yard with a sierra in and cut the legs out ans weld them in yours, its not a pretty job but once its done you know it will be sound
either that or find a decent cosworth shell and stick your bits in it
your's does look quite bad i'm afriad
Old Apr 30, 2009 | 05:46 PM
Mike Kerbey's Avatar
Mike Kerbey
fuk me thats bad! good luck on getting it back on the road!
Old Apr 30, 2009 | 06:02 PM
ybturbo's Avatar
ybturbo
I 've never seen one like this!!! Hope you fix it soon...
Old Apr 30, 2009 | 06:12 PM
charlie luciano's Avatar
charlie luciano
Cheers Ian mate
Is that the near side? if it is I have got a new chassis leg for you if ya intrested
Luciano
Old Apr 30, 2009 | 06:13 PM
Cossy Mike's Avatar
Cossy Mike
Bad news mate.....hope you get it sorted...
Old Apr 30, 2009 | 06:14 PM
col cos1's Avatar
col cos1
after all the sierras ive owned,the rear chassis legs is the weakest point
ive seen so many cossies with this,although yours is pretty extreme to be honest
people even bond plates on top and underseal to sell them
ive had one that needed welded,but i couldnt have a car knowing that so sold on,the reason i bought my 3 door is they were solid and untouched
if i was you id weld it and punt it on
youl be lucky to get a sierra in scrappys these days,unfortunatly most were bought for banger racing
Old Apr 30, 2009 | 06:16 PM
Barry R's Avatar
Barry R
Like I saaid though if they are the same as a 3 door then I have the pair
Old Apr 30, 2009 | 08:54 PM
an1mal_69's Avatar
an1mal_69
Originally Posted by charlie luciano
Cheers Ian mate
Luciano
cheers dude, but sods law, its the O/S where did you source it from, are they still available.?
Would rather fit a new 'un..but if i cant get one 'Barry R' ill deffo take you up on that offer..!!
The car is a 2wd saph' stg3 with a fresh motor. I bought it Jan & although i had a quick scout underneath i missed this, but to be fair the rest of the car is spot on bar some surface rust under the spare wheel well.
Any tips on ripping the back end to bits, will probably have to drop the diff an trailing arms to get into it proper..
Old Apr 30, 2009 | 09:00 PM
LHD220Turbo
my god, dont ask him that, he went all the way to Spain in person to get it, only to discover it was the wrong side!
Old Apr 30, 2009 | 09:06 PM
Barry R's Avatar
Barry R
Its really easy to pull the back end of only 16 bolts 2 brake pipes handbarke cable easy
You will struggle to find new 1s mate ask Charlie
Old Apr 30, 2009 | 09:58 PM
rs2klee's Avatar
rs2klee
K***LMT
hi i have a saph cossie going to the scrap soon, your welcome to come down and cut out what you need, i gota strip the rear end and its only going to be a dead shell. once its stripped come and take it away cut what yu want off it! ! or just come down to have a look !? not sure where you are tho to be worth it ?
Old Apr 30, 2009 | 10:34 PM
charlie luciano
Near side is still available from Ford but back order from Germany only, there are none left in this country, finis number is 1644593
Off side sadly are no longer available at all, that is why I went all the way to Almeria in Spain to pick up what I thought was the last last off side leg in the world, it had the correct part number which for the O/S is 1644591 but sods law it was a near side one Bugger
A decent second hand o/s one will be the way forward for ya
Luciano
Old Apr 30, 2009 | 11:00 PM
Paul_RS's Avatar
Paul_RS
Could a good welder not repair that? Could be worth talking to Jacko off here?
If you are happy with the rest of the car I'd repair it and enjoy the thing!
Old May 1, 2009 | 09:41 AM
It's a simple repair, and done correcty is going to be a load less hassle than cutting out a complete section etc.
My view is this why do a perfect pristine job on a 20 odd year old car like this, as this is just the first of many rusty bits that need doing each year.
It's the same case with my dads xr4i, patched up each year for mot, but getting fed up of doing it now, so getting another shell.
Old May 2, 2009 | 07:52 AM
jacko's Avatar
jacko
that aint as bad as it looks
its just that when you firt see it you think oh fuck its a nacker but its only metal at the end of the day its easily sorted
Old May 2, 2009 | 08:09 AM
Harris.'s Avatar
Harris.
+1. Ive seen a few go like this, easy job to sort dont panic !!!
Old May 2, 2009 | 08:11 AM
cossie604's Avatar
cossie604
^^^ what he said.....once you've stripped it down ie got rid of all the crap, it wont look bad at all. Nice saturday repair for you.
Old May 2, 2009 | 08:21 AM
andy.mac's Avatar
andy.mac
Cheers Ian mate
Luciano
looks like the near side to me in pics
Old May 2, 2009 | 08:38 AM
cossie604's Avatar
cossie604
Yeah I'd agree with that, deffo N/S.
Old May 2, 2009 | 08:44 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Don't know if they ship to the UK...
http://www.atp-autoteile.de/Product.aspx?p=5291331
Old May 3, 2009 | 02:48 PM
an1mal_69's Avatar
an1mal_69
cheers for the comments guys, ive just made room for it in the garage today (had to dump the cabby out back for while..hope the roof dont leak), so gonna strip it down over the next wk or so.
It is the N/S yea..feck knows why i put O/S. :$
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
SMILER258
Sep 28, 2015 09:04 AM
oldskooldanrst
Sep 27, 2015 04:02 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
davidfordrs
Sep 21, 2015 04:23 AM
