N.O.S. Parts
Escort Cabriolet Owner
ok its with regret i'm selling all these but i had to clear a friends unit out as it was sold from underneath her so she sold everything on which i purchased the bits she couldn't identify so i have had the job of trying to identify all the parts so here the bits i've identified so far and prices are rough prices as i'm not sure what these bits are worth so prices are O.N.O and Plus postage
here goes
mk4 fiesta 96' fuel pipe filler assy £10
ford 1.6d 1.8d fuel filter £2
esc mk5 1.8d thermostat sensor assy £10
fiesta mk3 central lock switch £5
transit mk4 caliper kit seals £10
sierra mk2 steering column surround (top) £5
sierra dohc round air filter £2
mondeo mk1 wheel cylinder £3
sierra p100 fuel and water temp gauge £10
mondeo mk1 rear ashtray raven £3
mondeo mk1 steering column bearing £5
esc mk5 front engine mount £10
mondeo mk1 rear heated screen switch £2
esc mk5 (cossy) central lock switch assy £5
fiesta 96 5dr rear interior handle armrest piece £2
escort mk3/4 glovebox lock + key £30
mondeo mk2 RH door lock assy £15
esc mk4 rear window ariel amplifier £5
esc mk5/6 van rear axle counter plate £10
mondeo mk1 boot lock + key £5
esc mk4 1.8d air filter £3
mk3 LH door glass mirror £3
maverick 97 iso cable £5
esc mk5/6 boot cover rr lights £3
mondeo mk1fuse panel cover (black or beige) £3
suspension arm bush esc cossy 2.0 £5
oil filler cap sierra late screw type £2
esc mk5 1.8d n/a w/pump gasket £1
galaxy brake + clutch control pipe assy £15
fiesta 89/94/96 1.8d lower timing cover less p/s + a/con £5
esc mk5 efi 1.6 cvh inlet gasket £1
esc mk5 brake and clutch quadrant cossy mt75 r=58mm £5
fiesta lower crankshaft bearing 8/88-12/88 £2
mondeo mk1 RH door mirror glass £5
ka door mirror interior trim panel warm olive £3
sierra 87 crankshaft main bearing 0.5mm 7/88-2/93 £5
transit 2.5d 84-89 rear crank seal £3
transit 95/tourneo egr valve £25
galaxy brake fluid cap £5
esc mk5 front brake + caliper fixing parts £2
transit 86 oil seal manual transmission £3
sierra 84-86 rev lamp sensor £5
mondeo mk1 radiator cap £2
sierra 7/88-2/93 dist rotor arm £5
esc mk5 3dr central locking door cable £3
transit 11/85-8/91 rear wheel brake drum grease retainer £3
mondeo mk1 estate 4/93-8/96 rear suspension bush £3
crankshaft bain bearing 11/77-8/82 granada deisel £3
transit mk4 wheel stud £2
mk4 esc rear gearbox bearing £5
ka rear bumper bracket LH £5
esc mk5 heater knob £2
transit 86 11/85 - 8/91 steering rod assy £10
transit 95/tourneo 03/89 main crankshaft bearing £3
fiesta 96 1.1, 1.3 cvh timing belt £2
mondeo mk1 fuel tank filler pipe housing £10
sierra 82 RH bumper mounting £5
fuel filter transit 88-91 ohc 2.0 cfi d £3
mondeo mk1 interior light £2
esc mk5 3/4/5 dr hcs 1.3 brake shoe lining kit £5
fiesta 96 exhaust mounting £3
sierra 87 output shaft oil seal £3
mondeo mk2 front seat hinge £3
mondeo mk1 cd changer lead £30
transit 11/91 - 11/92 emission control filter assy 2.5d £15
esc 8/88 - 1/89 hcs valve push rods £3
esc 91-93 RH manual window regulater £3
kent engine exhaust valves (138 in total) £2each or £200 for boxfull
ok guys thats the first lot and prices are a rough guide as not sure what some of these parts are worth
also prices are plus postage
parts are located in leicester collection is also welcome
can post pics of any of the parts as requested
thanx alain
here goes
thanx alain
