lamba sensor in a cossie
can u use any type of sensor or does it have to be a certain type in particular, I'm getting a gauge fitted and just wanted to make sure I get the right sensor
fitting in a T34 63 housing
on the subject, there's four wires coming out my lambda sensor, 2 white, a grey and a black if i recall correctly!
How are there wired up again?
p.s. sorry to steal your thread
i'm not saying i do know, i'm saying probably
connect it up wrongly, and it's knackered, so if you value it at all you should stop being lazy and get the part number and search it out properly.
here you go, lazy bugger
http://fpuk.co.uk/products/lambda.htm
lol thanks mate! you've been a help once again, just been outside getting mank with oil coz my oil feed is buggered, so i've been not so laxy
i'll get that wired up now then! many thanks!
check my link mate, they sell universal ones cheaply. a 1 wire one will be good enough, although 2 may be slightly better. any more than 2 wires means it has a heater in to get up to working temperature quicker, but it's not really necessary when located in the turbine housing and not being used for closed loop control.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
