2wd escort cosworth
Old Apr 22, 2009 | 09:16 PM
b-k's Avatar
b-k
Default 2wd escort cosworth
Hey.. i am coverting my escos to 2wd.
is there anyone here that has done this before? experiences?bad writing i know
i am using the t5 gearbox , the 7,5 diff from sierra cos ,etc
i am building the engine for 500 bhp.
the car has been totaly restored..
this used to be the car on my profile photo
Old Apr 22, 2009 | 09:26 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Getting popular now 2wd'ing the escos.
My project escos is going 2wd....
What do you want to know?
Dan
Old Apr 22, 2009 | 09:32 PM
b-k's Avatar
b-k
hey. i know that the axel has to be shorter. but is it the front of the axel or the rear part you have to cut? and is 35mm the right length?
Old Apr 22, 2009 | 09:40 PM
b-k's Avatar
b-k
white plenum
Old Apr 22, 2009 | 09:47 PM
SillyFezzaMk1
Rubber Rhino Crew
rear prop requires shortening by 60mm
Head over to escortrscosworth.com this thread has been covered lots of times with all the answers in one place there.
Dan
Old Apr 23, 2009 | 08:44 AM
PT's Avatar
PT
Dan@Rapidford has a 2wd escort, or atleast he used to
Old Apr 24, 2009 | 10:55 AM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
I still do and I've got it back out now
Old Apr 24, 2009 | 02:34 PM
SillyFezzaMk1
Rubber Rhino Crew
Got any pics or a link to a thread about the car?
Dan
Old Apr 24, 2009 | 03:07 PM
alo's Avatar
alo
Is it 100 percent 60mm. I've heard verious different size's now.
I called abc motorsport yesterday, to see if they would do the prop for me,according to fast ford magazine they are big in the rwd escort cosworth scene.
But they said they got it done by another company and said i'd be better off finding someone else to do it.... I couldn't even get an answer out of him on how much to remove as he couldn't remember. Chusdy!
Old Apr 24, 2009 | 11:56 PM
cossie daz's Avatar
cossie daz
sure Dan at rapid ford could help if you ask him
I bought a few bits of him and very helpful and nice bloke,
Old Apr 26, 2009 | 09:29 AM
Roger The Dodger's Avatar
Roger The Dodger
That was the old owners of abc who built that rwd escoz so the new guys probably would not no ...
The answer to your questions is yes its 60 mm and its best to remove it from the front of the rear section if that makes sense..
If you get stuck send it to me ill shorten it for you ..
Hope this helps .
Old Apr 28, 2009 | 02:47 PM
Dan@Rapid-Ford
Dan
There is a thread in resto room but TBH its nothing special. Its got a few nice bits on it and it looks nice but thats about it not much to talk about really.
I'll update the post at some point with some arsing about pictures shortly.
Dan
On another note if you make it 60mm shorter it makes it easier to get the prop on and off from the pinon on the diff.
Mine was made 55mm and is a bastard to get off
Old Apr 28, 2009 | 02:49 PM
Dan@Rapid-Ford
You could send the prop to Reco prop in Luton they have done a couple for me in the past but they are expensive.
Old May 5, 2009 | 07:10 PM
alo's Avatar
alo
cheers for the heads up
Old May 27, 2009 | 12:00 AM
alanfordtw-15's Avatar
alanfordtw-15
ive said it before.
if you find the output shaft from a granada automatic gearbox you do not need to touch your prop. it slips into the t5 and bolts onto the rubber donut
Old May 27, 2009 | 10:06 PM
ballbag42's Avatar
ballbag42
ive got a prop for mine i can give you the overall length tomm night compared to a norm 2wd one if you want
Old May 28, 2009 | 04:11 PM
alo's Avatar
alo
yes mate, that would great if you can. So I can check my figures. I'm going to a company in bexley heath, kent called J.w Engineering to get the work done and they want to know exact measurments. Measure twice and cut once and all that.
cheers Aaron
Old May 31, 2009 | 11:39 AM
alo's Avatar
alo
Originally Posted by alanfordtw-15
ive said it before.
What shape granada?
I tryied using a scorpio granada prop I had sitting on the side and it was way too long.
Also can a 4wd prop be used?
Regards Aaron
Old Jun 2, 2009 | 07:16 PM
dom123's Avatar
dom123
ive done my conversion last month and taken 60mm out of the rear section and its Too f**king short and i'm now going to have a spacer made between the prop and diff.
to make the prop fit like it does on a standard to 2wd saph it would have to be shorten to 48mm on my escos but to give room i wish id shortened mine 52mm to be safe now mine simply is not in the gearbox far enough.
Old Jun 8, 2009 | 11:48 PM
alanfordtw-15
What shape granada?
Regards Aaron
it is any automatic granada you need from 89 on. it is not the whole prop you use but only the output shaft from the auto box that is about six inches long and immediatly turns into a rubber donut triangle flange when it exits the gearbox.
obviously this then bolts onto the standard rubber donut on your standard escos prop.
i will take a pic of the spare one i have and also the one fitted to my escos when i get it back from the painters
Old Jun 9, 2009 | 02:53 PM
alo's Avatar
alo
Ah so you put this on an escort cos prop not on a 2wd one. Will try to sort this out.
Cheers bud
Old Jun 12, 2009 | 08:48 AM
rs cosworth's Avatar
rs cosworth
Can't you just take the front drive shafts out
Old Jun 12, 2009 | 09:39 AM
grcossie's Avatar
grcossie
No you can`t. Senter diff will not give all torque on rear wheels
Vincereese
Jun 1, 2023 09:14 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
